Adjustable Cam Gears - OGs Help!
Was looking at buying the GMR cams for my car, then adding bates solid lifters, then started looking at what numbers i was expected to gain, compared to what i would be spending for everything, and while on the phone with Fred from SMG we both were pondering, what about adjustable cam gears? could I get not nessicerily the same numbers but maybe half just by using those? any help is appreciated
on the stock cams i dout you would see a big power increase unless the cam centerline is off a few degrees
COMP CamsŽ - Sorry...
Effects of changing cam timing, with dyno graphs - Turbobricks Forums
I just can't justify the amount it would cost for gmr cams plus Bates solid lifters plus installed vs the maybe ten HP I would get from it
Which is why I was pondering the cams gears
Last edited by 07MetallicSC; Nov 13, 2010 at 06:50 PM. Reason: Automerged Doublepost
Eh I still didn't see anything that says like stage one will net you this etc. Stage 2 cams have requirements such as nbs and valve springs which I have awaiting instal but again if I'm going to be spending 700plus for cams I want multiple testimonials with thoughts after instal, dyno sheets etc. Basically I want to be sold by customers of the cams to buy them.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
