Adjustable Cam Gears - OGs Help!
Old Nov 12, 2010 | 10:35 AM
Was looking at buying the GMR cams for my car, then adding bates solid lifters, then started looking at what numbers i was expected to gain, compared to what i would be spending for everything, and while on the phone with Fred from SMG we both were pondering, what about adjustable cam gears? could I get not nessicerily the same numbers but maybe half just by using those? any help is appreciated
Old Nov 12, 2010 | 01:04 PM
Frew's Avatar
I think adjustable cam gears and the stock cams showed decent gains
Old Nov 12, 2010 | 01:23 PM
link?
Old Nov 12, 2010 | 03:36 PM
ziggity's Avatar
I thought you need adjustable cam gears if your going with different cams anyways?
Old Nov 12, 2010 | 03:40 PM
ls1fbody's Avatar
Haz l33t wheelz.
GM didn't even run the GMR cams in the TA balt.
They ran adjustable came gears.
Old Nov 12, 2010 | 03:43 PM
Going to use stock cams and possible cams gears
Old Nov 13, 2010 | 07:02 AM
Good to know. Any links for info?
Old Nov 13, 2010 | 11:44 AM
mrbelvedere's Avatar
on the stock cams i dout you would see a big power increase unless the cam centerline is off a few degrees
COMP CamsŽ - Sorry...
Effects of changing cam timing, with dyno graphs - Turbobricks Forums
Old Nov 13, 2010 | 12:44 PM
I'd be happy with 5hp
Old Nov 13, 2010 | 01:55 PM
for the cost of the gears its not worth it but good luck
Old Nov 13, 2010 | 02:16 PM
Its about on par for what we pay and get out of intakes...
Old Nov 13, 2010 | 02:20 PM
not realy it just depends on what intake you would make more power with zzp cams
Old Nov 13, 2010 | 02:28 PM
Areas post said gmr
Old Nov 13, 2010 | 03:46 PM
selfinfliction's Avatar
few of us have seen over 400whp with stock cams and no cam gears... why waste the money?
Old Nov 13, 2010 | 04:05 PM
Good point. I'm trying for 300 whp on stock blowet
Old Nov 13, 2010 | 05:46 PM
gmr cams are good cams but noy lash adjuster friendly zzp cams are
Old Nov 13, 2010 | 06:50 PM
I just can't justify the amount it would cost for gmr cams plus Bates solid lifters plus installed vs the maybe ten HP I would get from it
Which is why I was pondering the cams gears
Last edited by 07MetallicSC; Nov 13, 2010 at 06:50 PM. Reason: Automerged Doublepost
Old Nov 13, 2010 | 07:01 PM
get the zzp cams all the hard work is done drop them in and tune
Old Nov 13, 2010 | 08:12 PM
They don't need lifters or any other parts? I havbt heard of any 2.0 with them, is there proof of positive gains?
Old Nov 14, 2010 | 12:47 AM
go look on there website turbo tim has been running them and you use stock lifters
Old Nov 14, 2010 | 10:26 AM
Eh I still didn't see anything that says like stage one will net you this etc. Stage 2 cams have requirements such as nbs and valve springs which I have awaiting instal but again if I'm going to be spending 700plus for cams I want multiple testimonials with thoughts after instal, dyno sheets etc. Basically I want to be sold by customers of the cams to buy them.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
biniecki
Oct 25, 2015 02:23 PM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
nathan112i
Sep 30, 2015 07:12 PM
