advice on changing pullys
Old May 25, 2007 | 02:34 PM
quadracer0387's Avatar
if i swap a 3 inch to a 2.8 pully on my supercharger do you think i will need to change anything else on my car such as a belt tensioner or injectors or do i need a retune.
i herd it was ok to run a 2.8 with gm stage 2 retune i just want to no what other people think
Last edited by quadracer0387; May 25, 2007 at 02:34 PM. Reason: Automerged Doublepost
Old May 25, 2007 | 02:38 PM
Acidangel_5.0's Avatar
dont do it... your elevation with screw you.. if you were on the coast.. might be able to pull it off...
just pick up a 2.9 from nherb.. will give you a little more pep and you should be fine... no point in being risky when your talking a few hp/tq difference
Old May 25, 2007 | 02:56 PM
braddddddd991's Avatar
2.9 man
Old May 25, 2007 | 03:02 PM
yellowcobaltss05's Avatar
get a 2.9 pulley
Old May 25, 2007 | 03:26 PM
where can i pick one up at and will it fit the gm stage 2 hub
Old May 25, 2007 | 03:30 PM
an0malous's Avatar
being on the coast would be worse.
hes at about a thousand feet,
being on the coast, at "sea level" will allow more boost.
the higher up you go. the less boost you get.
Old May 25, 2007 | 04:09 PM
your right... but this is beyong how much boost.. elevation plays a much larger role in tuning.. not talking about how much #'s..
Old May 25, 2007 | 05:13 PM
an0malous's Avatar
ahh k.
ya learn somethin new every day i didnt know tuning got harder at alt.
turbochargedss2012
Sep 20, 2023 12:17 PM
importkiller
Sep 30, 2015 07:18 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
DocSvensk
Sep 27, 2015 02:24 PM
jmelton327
Sep 26, 2015 10:04 PM
