Aeroforce Interceptor users please read!
Old Jul 16, 2008 | 04:18 PM
dperkins1988's Avatar
When you install the gauge, does it immediately show you the IAT1 and 2s? or do you have to buy something like a air temp sensor to install in the intake? someone told me that you have to do this in order for your gauge to read the proper air intake temps. Any truth to this?
Old Jul 16, 2008 | 04:22 PM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Nope. Itll read them right outta the box. You jsut gotta set it up.
My top one here is reading IAT1 and IAT2, about 10 mins after I had installed JUST the gauges.
Old Jul 16, 2008 | 04:24 PM
Ok thanks for the help is it fairly simple to setup?
Old Jul 16, 2008 | 04:25 PM
lewisb13's Avatar
Its so easy a caveman could do it. Good luck getting the correct power to them....
Old Jul 16, 2008 | 04:49 PM
what you mean by the correct power? u mean tapping into a power source?
Old Jul 18, 2008 | 12:20 AM
OrngBalt's Avatar
I didnt have to power mine... Mine takes power right from the OBDII port
Old Jul 18, 2008 | 04:16 AM
runriot's Avatar
so does mine, took me a whopping ten minutes to remove the boost guage, run the wire to the obd port, plug it in, and fire the car up.........no extra power wires needed.
Its funny because the guy that I bought it from had the same year redline, and he needed external power. Guess my car was special.
Old Jul 18, 2008 | 08:11 AM
lewisb13's Avatar
The SSSC models dont work like that.
Old Jul 18, 2008 | 09:37 AM
infernica's Avatar
Seriously.... lol, if those cavemen **** come to this site to sue....Imma be pissed. haha
Well, if the ss/sc doesn't do it like the redline, how did you get your's powered? Help some brother's out!
Old Jul 18, 2008 | 09:52 AM
OrngBalt's Avatar
Well if you havea boost gauge, you can just splice into that power line. If not get some wire and run the power line across to the fuse box and use a tap.
Old Jul 18, 2008 | 10:25 AM
Deathscythe's Avatar
I have a dual gauge setup and the cable is running into the obd2 plug. My primary will momentarily shut-off and come right back on but my secondary never does that. Also when I start the car, the gauges won't start unless I unplug them and hook it up again.
Old Jul 18, 2008 | 10:30 AM
rhanes216213's Avatar
Just run your power wire to the fuse box and use a tap a fuse kit. Plug it into the sunroof fuse and run the black ground wire to ground. Not hard.
Old Jul 18, 2008 | 11:50 AM
zinner's Avatar
Moderator Alumni
For the most part the guage displays the values provided by the engine computer and it's sensors. There are a few features on the new versions that allow you to add your own sensors (two addition) with a 0-5v output. There is also a HP and MPG feature based on your engine PCM values.
Old Jul 18, 2008 | 11:52 AM
lewisb13's Avatar
You need to run auxiliary power. I had this problem initially.
Old Jul 18, 2008 | 12:08 PM
IMADreamer's Avatar
Why do you say that. It took me maybe 10 minutes to install the thing from start to finish and that is with running a power line from the fuse panel. It's easy.
Old Jul 18, 2008 | 12:09 PM
lewisb13's Avatar
For those of us who tried to use the radio fuse, it took, much, much, much longer.
Old Jul 18, 2008 | 09:49 PM
theneelster's Avatar
That's messed up...I have a 2k5 redline and I need external power.
Old Jul 18, 2008 | 09:52 PM
outtamymind's Avatar
for those of you who have the issue of having to unplug and replug the guages in to get them to work properly on the back of the gauge there is a little red jumper. remove it as it is not required for the cobalts and it is what's causing that particular problem
Old Jul 19, 2008 | 07:15 AM
hungryhip-ccp's Avatar
they need to read... that would annoy the **** out of me. ^^^this is true, easy fix^^^
Old Jul 19, 2008 | 02:24 PM
actually when i first installed a couple of the gauges on a few buddies pages, the part where they explained about the jumper was really confusing and from my understanding (its been a while since i've read the instructions) it didn't say anything about removing the jumper for the cobalts. so after some trial and error i figured it out with some help from a buddy. so since this is the case i figured i would also share my info so people can use their gauges properly
Supercharged06SS
Dec 11, 2022 04:47 PM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
