aftermarket boost gauge ??
Old 10-21-2008, 08:36 PM
JDMjunkie's Avatar
So I'm looking into a Defi boost gauge, i hate the factory autometer. Does the car throw a CEL with the boost gauge disconnected? Has anybody changed the stock one? Where did you splice in for the wiring and vacuum lines?
Old 10-21-2008, 08:37 PM
Perfect.disguise's Avatar
Why would it throw a CEL?
Old 10-21-2008, 08:44 PM
rockSTAR_SS's Avatar
No CEL on my boost gauge. I bought the 30/30psi mechanical Autometer ultralite II boost/vacuum gauge. I simply wired my power to the pink wire originally running to the stock gauge and grounded it off under the dash. Boost lines are fairly easy to hook up. Find your MAP sensor, cut the vacuum line AFTER or BEHIND the MAP sensor and install you "T" there for the aftermarket boost gauge. Here's a little help:
-----(vacuum line)------[MAP sensor]--------T--------
Of course off the "T" you'll run your vacuum line to the gauge. Hope this helps
Old 10-21-2008, 08:45 PM
brandondrecksage's Avatar
Why not get a good ole 50 dollar autometer mechanical gauge? Its really easy to hook up if you follow the how to in the how to section.
Old 10-21-2008, 08:47 PM
With the boost gauge unplugged, it won't throw a code, but with the MAP sensor unplugged, no boost will be made.
Well...boost will be made, but the computer won't know how much so it'll run pretty crappy. I experimented and made the conclusion that my car will only make 2.6 psi with the "t" on the wrong side of the MAP sensor or if the MAP sensor is unplugged.
Old 10-21-2008, 09:42 PM
JDMjunkie's Avatar
thanks for the info everyone! I wasn't sure about the CEL....everything is tied into a module of somesort these days.
DarrenGC
12-24-2021 01:55 PM
Sl0wbaltSS
11-21-2018 11:11 PM
01-12-2016 12:01 AM
ineedacobaltss
11-07-2015 02:25 PM
09-27-2015 08:53 PM
Quick Reply: aftermarket boost gauge ??
