alky injection installed, less boost?
Old Oct 17, 2006 | 08:49 PM
Mase's Avatar
I might do a "how to install" on the kit I got from TAG Racecraft cause I'll be installing their newest version with dual nozzle (both M1's). I only have one nozzle right now.
Old Oct 17, 2006 | 09:58 PM
patathSS's Avatar
Are you using a solenoid to control when the line is open to flow? I ordered a single M5 nozzle with my DO kit.
Old Oct 17, 2006 | 10:11 PM
djt81185's Avatar
It works great lol...I have it and heart it
Old Oct 18, 2006 | 04:06 PM
Mase's Avatar
no just a check valve. Remember it's alway better to use more nozzles than one large one as it atomizes better.
Old Oct 18, 2006 | 04:12 PM
patathSS's Avatar
Well I am using a progressive controller not just a boost switch. I have heard horror stories of the vaccuum causing the meth mix to suck up.
Edit: Also, are 2 M1 nozzles going to be enough? I would go with an M3 at least.
Old Oct 18, 2006 | 05:20 PM
Mase's Avatar
no, I just use the switch. Progressive really isn't needed on our cars as we get boost pretty much straight across, look:
33.7 absolute off the MAP is same as 19psi boost pressure. Also you can see a progressive off the MAP really will not act as progressive if your boost doesn't gradually build. Progressive would be better suited for a turbo application, on our cars as soon as the trottle opens enough we get instant close to peak boost.
As for meth getting sucked up, I haven't had a problem.
I think 2 M1's should be good, if not I'll put in 2 M2's....still testing different setups.
Old Oct 18, 2006 | 08:58 PM
djt81185's Avatar
Progressive def does make a difference...our boost curve build up based on rpm...at low rpm then it ramps...ive logged it and charted it
Old Oct 19, 2006 | 04:14 PM
BravoPuma6's Avatar
Originally Posted by FAST06SS
I don't think i can take much more of the BS info being shared on here
lol my first day here and all the crazy stuff i read that didnt make sense is killing me lol
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
SlowSaturn
Sep 28, 2015 11:03 AM
