Am I boost stacking?
Old Oct 6, 2009 | 04:00 PM
06SS ALL DAY's Avatar
Last night I did a WOT pull in 3rd and half of 4th. Temp outside was 55 degrees with little humidity if that matters. 3rd gear I seen 15lbs and in 4th i was seeing 16... is that possible with a 3.1 pulley? my tune is the zzp stage 2. air box mod, stock exhaust... zoomer or turbo tim feel free to chime in. I wasnt aware the M62 can boost stack. I know the M90's do and are more prone to it...
Old Oct 6, 2009 | 04:09 PM
phatnackySS's Avatar
could be a clogged cat. not to sure what you mean by boost stack, if you mean air stacking then that's the principal that all roots blowers(not twin screws) work. higher than average boost often means a restricting somewhere.
Old Oct 6, 2009 | 04:18 PM
blackbolt89's Avatar
sounds like he's got a very good point.
do you feel any hesitation? anything different than normal driving?
Old Oct 6, 2009 | 04:27 PM
mmcgee123's Avatar
Seems like a possible clogged cat
Old Oct 6, 2009 | 04:39 PM
Zach06CobaltSC's Avatar
That seems like a hell of a lot of boost for a 3.1 inch pulley, granted he is on stock exhaust. I run a 2.8 pulley and see 15 to 16 lbs. I highly recommend you check your cat and upgrade your exhaust. Boost is just a restriction of air flow, it's not power. The less boost the less stress on your motor.
Old Oct 6, 2009 | 04:51 PM
Karlen89's Avatar
Im Stage 2 with 15-16 lbs, catless dp
Old Oct 6, 2009 | 06:38 PM
no hesitation when driving normally. maybe ONCE and i really mean this ONCE IN A BLUE MOON. maybe once in 2 months on a WOT. ill have a hesitation for a split second. thats so rare its not even funny. a clogged cat wouldn't that throw a code from an o2? but i guess that depends on which cat. i believe GM has a warranty on the exhaust system to 60k or 100k i forgot which one. either way if i bring it to the dealer. what should i say? i cant say hey im aftermarket stage 2. im running more boost than usual. can u check the exhaust system for a clogged cat? ya feel me? lol.
Old Oct 6, 2009 | 06:53 PM
06cobalt racer's Avatar
just tell them that the performance is lacking. and that the exhaust sounds clogged. maybe that will work.
Old Oct 6, 2009 | 11:30 PM
i know the emission system is covered by a FEDERALLY mandated warranty. so if they say no just call the EPA or whoever the **** cares about car emissions. lol.
Old Oct 7, 2009 | 01:44 AM
ill try
Old Oct 7, 2009 | 01:50 AM
steddy2112's Avatar
Old Oct 7, 2009 | 01:59 AM
Originally Posted by steddy2112
stop trolling please. thank you
Old Oct 7, 2009 | 02:01 AM
steddy2112's Avatar
Clogged cat.
No trolling, but air stacking on top of itself in the intake mani is how this supercharger works IIRC.
Old Oct 7, 2009 | 02:19 AM
hatrickstu's Avatar
shitty exhaust flow. im on a 2.85 and barely see 15 at 7200...
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
