ANOTHER build thread
Old Aug 9, 2007 | 01:16 AM
  #51
sunfirejoe's Avatar
i ran out of space lol, ummm, yah fully ported and polished head, new valves and dual coil valve springs, 5 angle valve job, and aswell a custom set of ev0 262 grind on my cams, so well see how she runs, next is turbo
i think i need a sponsor though thats not me, im the only one dishing out money on such a crazy build, best thing is ive done it all myself,
  #52
Witt's Avatar
With the cams, I assume they are regrounds. Did you shim the lifters?
Also when you deleted the balance shafts are you sure the oil holes are plugged. Noisy valvetrain could be because of oil starvation.
Old Aug 9, 2007 | 01:21 AM
  #53
sunfirejoe's Avatar
the middle ones are plugged i know for a fact i did it myself, the only concern was levelzero only said the middle one needed to be but in DSM's all the other bearing need to be turned, hmmm, i think ill install an oil pressure gauge tomorrow as i think my factory one is toast
, and yes i had the lifters shimmed, as i was watching i tihnk it was your thread, it was all done professinally on the head side of things, i ran out of time
im pretty sure i overtorqued(accidental, cover was already on, and notice that the book said inch pounds), but not a 100% positive, my cams so meaning it would cause sticky lifters would it not
Old Aug 9, 2007 | 01:28 AM
  #54
Witt's Avatar
What did you overtorque? The only thing I can think of that would affect lifter performance would be to overtorque the cam cap bolts but they snap at extremely low levels of torque. The lifters are stationary so unless they are collapsing not much can affect them other than oil starvation and improper clearance.
You can try taking the cam cover off and moving a lifter to see if its tight. Maybe pour some oil into the cam cover while the engine is running to see if it quiets up at all. Just some ideas.
Old Aug 9, 2007 | 01:31 AM
  #55
sunfirejoe's Avatar
yah i think ill try the cam cover off and pour some oil, it was the cam caps, i never snapped one bolt so im assuming im safe, hopefully im not having oil pressure issues, if i am, time to start looking deeper , but we all knwo where that will be lol
Old Aug 9, 2007 | 01:33 AM
  #56
Witt's Avatar
Good luck and keep us updated. If its running, it can't be that hard to fix the rest.
Old Aug 9, 2007 | 01:37 AM
  #57
sunfirejoe's Avatar
exactly my thoughts, just a **** load of tuning to do, hook up meth, tune meth in, than run with nitrous in about a month, tune with nitrous, i have 2 active pcm's now too loll, oh well,
to do list
is
a. bleed clutch
b. case relearn
c. oil change
d. fix loud valvetrain
e. tune car for normal driving
f. tune car for meth
g. tune car for meth and nitrous
h. hit dyno and track
i. keep updated after step with new videos and pictures
Old Aug 9, 2007 | 01:41 AM
  #58
Witt's Avatar
LOL I remember saying those words. Yeah, I held out about 3 days.
Old Aug 9, 2007 | 01:44 AM
  #59
sunfirejoe's Avatar
see but mine isnt installed its just an ornament next to my bed
also i got this odd feeling 60 lbs an hour injectors arent gonna keep up
Old Aug 9, 2007 | 01:48 AM
  #60
Witt's Avatar
Haha nice. Yeah I believe my holdout on spraying on the new build ended with the phrase "eh **** it, I already know how to rebuild it" right before throwing the arming switch.
Redline Dan (djt81185) is maxing out 60lb injectors (110% duty cycle) sitting around 305-310 mustang whp. Best bet by far is to convert to a return style system which will allow much much better high vacuum injector pulses and better high pressure ones as well. You'll be able to stretch out the capability of the 60s a bit further.
Old Aug 9, 2007 | 01:50 AM
  #61
sunfirejoe's Avatar
damnit cuz i really think ill break 300 with my set-up lol
Old Aug 15, 2007 | 11:32 PM
  #62
sunfirejoe's Avatar
k guys clutch is bled, valve train noise is fixed, it needs to build oil pressure now, it takes longer, because no balance shafts,
my issue is now i cant get into any gears when the car is running, no problem, when its not, but big issues when the car is, any ideas would help, im so close to tuning
Old Aug 22, 2007 | 11:02 PM
  #63
firestorm's Avatar
did you take out the block, or what? wondering if your linkage is right
Old Aug 23, 2007 | 12:30 AM
  #64
sunfirejoe's Avatar
i know my linkages are right b/c it shifts fine when not running, the tranny shop seems to think its my throw out bearing
Old Aug 23, 2007 | 12:35 AM
  #65
WSFrazier's Avatar
If it shifts fine when the car is off, then it is probably something with the PP/Disc/Flywheel or throwout bearing. Something not mating up correctly. Probably gonna need to lug the trans off and take a look. God I hate taking the trans off these cars. I would rather build the motor than do a clutch install.
Old Aug 23, 2007 | 12:38 AM
  #66
sunfirejoe's Avatar
thus why its at a tranny shop, i reallly really hate taking our trannys off
Old Aug 23, 2007 | 01:05 AM
  #67
saunders1986's Avatar
hahaha that peace of **** will never be done. ( i love pushing joeys buttons, HAHAHA)
lets race!
Old Aug 23, 2007 | 01:07 AM
  #68
victory_red_SS's Avatar
LSX RWD S/C conversion
lets race!
With his luck so far, mine may be done before his.
Old Aug 23, 2007 | 01:11 AM
  #69
he was supposed to be turbo.... instead he put the stupid s/c back on, broke my heart.......
joey if your hurtin so am i!!!!!!!!
Old Aug 23, 2007 | 01:15 AM
  #70
Why?
Old Aug 23, 2007 | 02:14 AM
  #71
sunfirejoe's Avatar
school
Old Aug 23, 2007 | 06:20 PM
  #72
firestorm's Avatar
is it possible to install the bearing backwards?
ive seen it done on smallblocks
Old Aug 23, 2007 | 06:27 PM
  #73
Sales@rebelautoworxs's Avatar
Not with the lsj Thowout bearing it's attached to the slave.
I'm still thinking the clutch isn't flat on the flywheel.
Old Aug 23, 2007 | 08:07 PM
  #74
rickay726's Avatar
ouch
Old Aug 24, 2007 | 12:56 AM
  #75
WSFrazier's Avatar
Yeah, something isn't mating up correctly inside the tranny it sounds like. Be sure to let us know when you can, this has me very curious.
