any advice in launching
Originally Posted by spooler
start off slow, and then get into it once the tires start to grab. find an adbandoned road and just practise 1st to 2nd shifts.
If you're at a track, from what I found with my 2.2l, I launch at about 5300 rpms, yes, I know some of you must think that's pretty high, but like blown 4-banger said, if you do it perfectly of letting out the clutch and pressing in the gas, you have no tire spin / wheel hop and wicked launch. It also helps that the track that's close to me just got repaved and has new rubber on there. But by doing this right, you can have an awesome 60' time and no tire spin, my best 60' for a 2.2l is 2.2.
your best 0-60 is what?
I haven't had the Cobalt to the track yet, but my '71 Camaro pulled a 2.0031 second 60 ft. time on street radials (not drag radials). If I were to run drag radials, or better yet, slicks, I don't see why I couldn't get 1.8, maybe as low as 1.6 second 60 ft. times.
I may end up with a broken driveshaft or rear end though, and I don't really want that.
Originally Posted by redbaltsssc
if you cant affored the torque dampener, take some permatex gasket sealer, red, squirt it into all the spaces in the mount and let it dry. stopped 90 % of my wheel hop...
I like real world cheap but effective advice
Ron
Originally Posted by ReMz
wow.... u should post this up in a topic
..... that is very interesting. i would prefer a torque dampner for proven performance gains and looks......... but i cant agrue with ur method. seems it would work "almost" as well.
I say "almost" because i tightened the brackets on my Ingalls VERRRRY tite and i don't see sealer matching that stiffness.
Make sense?
The silicone in the other mounts works well. I did that on my Calais....quite effective.
Don't want the dealer guys to see red? Use black GE silicone.....
Ron
Originally Posted by aj_92rs
That's 60' (feet) not 0-60 mph.
M/T thus far makes the best drag radial.
My nova hit a best of 1.37 this year...with radial slicks....and it busted the front U-joint, and the damage wasn't pretty.
Have fun!
Ron
Originally Posted by RonSS
Unless it's a pretty bad ass Camaro....it won't drop to a 1.6 60 ft time. But it could. That takes a car that runs mid 11's. 1.8 would be reasonable.
Have fun!
Ron
Have fun!
Ron
Yea. That's what I meant though. After future mods to the engine I may possibly be able to drop the 60' times to 1.6 seconds without busting the factory rear end. Of course welding the axle tubes will help keep that from happening.
Now, to answer the original question, practice, practice, practice. That's the only way. Practice with your car as much as possible. Get to know your car. Know what it likes and doesn't like. It takes practice to find that fine line between max acceleration and spinning the tires.
And don't let any newby tell you that a little tire spin is a good thing. About the only thing it's good for is (as I was just saying to Ron) is keeping factory suspensions from shattering to pieces. But you normally won't have to worry about that with regular street radials.
Oh yea. When you're done practicing, practice more.
Originally Posted by Blown 4-banger
I'v gotten 2.2 60' times launching from idle. You just need to get the gas and clutch exactly perfect, but you can launch HARD with no tire spin what so ever! I figured this out last time I went to the track.
NoBalt123
Sep 4, 2015 07:10 AM
