Any stageII DIYers?
Old Aug 30, 2006 | 03:36 PM
godsfshrmn's Avatar
Any stageII DIYers?
Have any of you installed your own stageII kits? I am curious as to how difficult the process will be. Which parts were the most difficult? Obviously removing the S/C pulley will be a pita. Also, how much louder was your SC with the smaller pulley?
Old Aug 31, 2006 | 07:11 AM
2K5SS/SC?'s Avatar
The blower is is easy to remove. 4 bolts, 2 elec. connections, and removing the intake pipe where it attaches to the throttle body. The injectors are a little harder to do because of the space alloted, but other than that it's an easy day. Oh, you will need a pulley puller to swap the pulleys. Make sure when you drive to the dealership, that you keep in low rpms, like under 3000. Have them reflash the PCM and viola enjoy Stage 2 until your clutch starts slipping.
Old Aug 31, 2006 | 07:57 AM
blown06's Avatar
^^^^ yeah what he said, diff get a puller pullet, zzp one worked awesome
Old Aug 31, 2006 | 08:13 AM
johnkb8's Avatar
what about the belt, how hard it that to get the old one off and put new one on, how do you do that
Old Aug 31, 2006 | 08:15 AM
R33P3R007's Avatar
360 L337 User
just like any other belt. use a wrench to pull tension off the belt and slip it to the side. once you have it off one pulley it will come off the rest no problem. But make sure you pay attention to the routing just in case.
Old Aug 31, 2006 | 12:51 PM
godsfshrmn's Avatar
So you ahve to actually remove the blower to take the pulley off?
Old Aug 31, 2006 | 12:56 PM
blown06's Avatar
yeah its easy though
blown06's Avatar
4 bolts and a couple of wiring harness and the intake tube
Old Aug 31, 2006 | 05:19 PM
Smarty Art's Avatar
Actually you have to take the supercharger off to take the fuel rail off to take the injecters off. You can change pulleys with the supercharger on. You might need help and if you don't know what your doing your best bet is to let the dealer do it.
Old Sep 1, 2006 | 09:53 AM
2K5SS/SC?'s Avatar
Changing the pulley with the blower on is damn near impossible. It is much easier to remove it. The fuel rail is held on by three 10mm bolts. The rail/injectors pop out after that. Each injector has an elec. connection and metal clip for removal. Easy days people. Oh, the wrench you need for the tensioner is a 15mm. The instructions that come with the kit are pretty decent, and do include pictures by the way.
Old Sep 1, 2006 | 10:01 AM
SS33's Avatar
Uhm totally wrong.
You can do the fuel rail and injectors with the blower on. I know I just did mine.
GM wouldn't make a stg 1 kit that required you to pull the blower.
For the pulley, with a Cobalt, you CAN NOT pull the stock pulley or press on a new hub with the blower in the engine bay. Redlines may have more room than we do, but it aint happening on a Cobalt.
Now once you have your new hub in place, YES you can swap out different pulley rings without removing your blower again. HTH
Old Sep 1, 2006 | 10:33 AM
BLKSS's Avatar
Originally Posted by SS33
Uhm totally wrong.
He is right on. Might have to let her cool off once you get to the installation but thats a no brainer.
Getaway_Driver
Jul 8, 2015 02:39 PM
carid
Nov 21, 2014 07:19 AM
Jraynes
Jul 5, 2014 01:48 PM
white07
Jul 16, 2012 07:12 PM
streetracinazian
May 11, 2010 01:10 AM
