Anyone recommend these solid mounts?
Old Aug 30, 2008 | 05:01 PM
thedubsack85's Avatar
Originally Posted by TurboTechRacing
First Bwoody is not a vendor here.... Nor did we slam them, we "re" stated they cause "false knock" which another member stated.
REALLY? SO BELOW WAS NOT YOUR ORIGINAL POST ABOUT BWOODY?
Might want to check these out: They are rated #1 on recent polls on the cobalt forums, and do not cause "false knock" like the Bwoody ones have known to do.
because one single member said he got false knock suddenly there known for it??
that's CHILDISH. and your the vendor? i had no false knock on my set and hardly really any vibration's unless it was a cold start..
Second, we are just stating another option for members that have had both and stated in the poll the TTR ones were rated much higher.
OMFG because your bushing mount's are rated higher according to a CSS.net poll you downtalk bwoody.. and this mean's what? nothing becuase your bushing replacement's ARE NOT full SOLID mount's...
ive said this before and ill say it again.. A BUSHING REPLACEMENT AINT A SOILD MOUNT..
if you want a solid mount get solid mount's but dont complain about vibration... my girl never did
for the record if people did what most poll's here say they would have blown up there car riced it out or dumped there gf..
Old Aug 30, 2008 | 05:27 PM
Raven SS's Avatar
Originally Posted by rrutter81
thanks for adding in on the convo, and if u want i can send you some of my formulas i use for narrowband tuning that work awesome for a DD (commute) + WOT for power. I know your well respected and would love the critique.
however i use regular hptuners and compare to my lc1 logs for WOT.
yea man my email is rotteneg6@yahoo.com and u can add me on aim from the left side of this post
and for the record ttr mounts cause false knock also...not at idle but better known as tip in knock or roll on knock...like a 5th to 3rd dump or stabbing it in 2nd.
Old Aug 30, 2008 | 05:36 PM
TurboTechRacing's Avatar
For a "split second" dumping in a lower gear like that, will cause even the stock setup to "knock", meaning a not modified car (stock everything)
That is not related to mounts; it is the "instant" shock of the clutch/drivetrain through the engine, that causes that.... Mounts have nothing to do with that, as even if you have the OEM mounts, you will still cause this to happen.
Old Aug 30, 2008 | 05:39 PM
Raven SS's Avatar
it wasnt a bash or something that i cared to argue about, im just stating what I FOUND with ur mounts, i would still recommend urs over solids.
Old Aug 30, 2008 | 05:40 PM
We understand this and knew this. We just wanted to make it clear to "others" that any mount has nothing to do with that (stock or aftermarket, it still does it).
Old Aug 30, 2008 | 06:15 PM
KillerBee's Avatar
someone has a real bad case of dick in the ass stop bashing TTR and get over your self
Old Aug 30, 2008 | 06:24 PM
theneelster's Avatar
Why did this turn into a bbq bash? Anyone want to knock Jason Smith's stuff too?
Originally Posted by Blown 4-banger
I have the billet poly mounts from ZZP and I love them. Installed easy, look great, and work really good. After a drive, I feel all relaxed cause its like sitting in a massage chair while you drive
Hilarious btw. Does it feel like a yugo?
Last edited by theneelster; Aug 30, 2008 at 06:24 PM. Reason: Automerged Doublepost
OrangeCoba
Oct 1, 2015 10:00 PM
footballplaya3k
Sep 30, 2015 09:39 PM
n20saturn
Sep 30, 2015 12:26 AM
