is anyone running with a 2.8 pulley and 42.5 injectors? Any probs???
trust me, im not new at this.
im going to find out the exact IDC tomorrow {saturday} if everything is cool. the 2.8 goes back on. the bad thing is, i have the 3.0 pulley pulling just as hard right now, if not better up top.
again, it also could be the wideband im using freaking out. which will be double checked tomorrow.
as far as the duty cycle. im using the config file that denny uses on this hp tuners logger as well. it could very well be wrong. i don't think anyone has taken the time to stick a tech2 on the car to see how gm reads things.
but we are about to find out!
this is an argument that will never end!!!! 42lbs & 2.8! ahh!! well im not adding to the dilemma but my friend blew his motor running this set up, but then again ive noticed that hp gains and engine realibility is never the same with lsj's. some ppl run fine and some people blow up.
my suggestion, like many, dont over do your injectors.
injectors duty cycle: GET SCANNED!
Last edited by Boost Fr33k; May 7, 2007 at 05:50 PM. Reason: Automerged Doublepost
i did a 2nd gear pull, with the tech2 on the car. pulled 17 m/sec in a 20-70 run.
on stage 2.
now, not much of a load like 3rd or 4th gear, but you get an idea.
this was also with my stage2-100 octane map, so there is less fuel in general, but not as much as one would think.
17.0 comes out to be about 67%
on stage 2.
on stage 2.
on stage 2.
then get flamed like none other. have i risked my car? yulp. not a big deal to me.
let me get some more time with a tech2 before i give a concrete answer.
just a heads up kids, running too big of an injectors is almost as bad as running too little.
you can only take so much fuel out
I was reading over on another board, some believe that using 60lb injectors are actually STARVING the motor of fuel, and the reason why it is always piston #4 is because it is also furthest away from the entrance feed of the fuel rail.
Source of the theory; maxed out fuel pump.
Think about it, you guys are using injectors with a flow rate of nearly TWICE the rate of the stock injectors.
I don't believe that GM would use a fuel pump that would support double the flow rate during production.
Exactly.
physical space, I remember reading about this exact issue and zinner and wopontour had a discussion about the actual size of the rail. Saying it is restrictive. Increasing the fuel rail size should help get fuel to #4 faster without increasing fuel pressure.
because the IDC for the stock injectors on stock pulley is averaging above 120% from thelast 5 logs of stock SS S/C's that I have seen.
IMO no...you can get a leaned out tune to get ur IDC down but thats a bomb waiting to go off. When I had 42's and a 2.8 anytime i went past 6000rpm i was maxing out my injectors and running leaner than I should have.
There is a guy trying to fabricate his own fuel rail, where the fuel inputs the rail between cylinder 2 and 3. What he is trying to do is distribute it more directly in the middle. Although cylinders 2 and 3 will still get the most fuel, the theory is a possible solution to our problems.
The GM injectors are not as good as the Bosch style injectors that are in the Intense kits. The IDC is higher from MY experience on the GM stage 2/3 injectors than on the 42.5#'s from elsewhere. But I can't speak for everyone.
FUELRAILS will OWN you down the road. Damn Fuel Pressure Probs!
2.8 + 42.5's = good for about 2 weeks.
the gm injectors can't handle it. pure and simple.
hell they can barely handle the stage 2 crap.
i wonder if there is a way to bump up the rail pressure. i know that the ecm controls that side of it. it doesn't give us the power in hp to do it.
