is anyone running with a 2.8 pulley and 42.5 injectors? Any probs???
Old May 9, 2007 | 11:50 AM
  #51
QuikSilverSS's Avatar
its back to hearsay, question....who has run into any problems with Stage 2 and 2.8? We have beat the IDC issue to death, just want to know who has had problems, not HP Tuners says my IDC's are over 100% so i swapped them out.
I have ran my 2.8 with my stage 2 for 7 months no issues at all, not saying its the best setup, just want to know if any problems have occured with people and this mod
Old May 9, 2007 | 12:50 PM
  #52
chevysalesman614's Avatar
I'm running a 2.9" pulley on my #42s. w/ no problems
Old May 9, 2007 | 12:54 PM
  #53
peck05's Avatar
ive been running a 2.79 pulley and my 42s for about 7 months now and i have not seen any problems as of yet, and i have had my car for onle 13 months and i have 31000 miles on it, so i do alot of driving and still no problems
Old May 9, 2007 | 01:29 PM
  #54
Area47's Avatar
Rent me! per hour
i wasn't refering to the idc, i was refering to the injectors going static at 6600 rpms on stage 2, on a 2007 car. i myself am not 100% positive the idc calc in hp is anywhere near right anyways, thats the least of my problems.
my problem is the injectors going static is was proven by three different wide bands. that is my problem right now. others may not have this. stick a wideband on it. it takes all of 5 mins to check and see
Old May 11, 2007 | 01:50 PM
  #55
Zooomer's Avatar
Supporting Vendor
This thead is asking for a simple answer to a complicated question.
A stock exhaust car is going to have 3 pounds more boost than one with a full exhaust setup. This alone will change how the injectors flow. Remember that fuel pressure is constant but it's the difference in boost to fuel pressure that determines injector flow rate.
To determine if the fuel pump is too small to run 60's, you simply need a fuel pressure gauge with a small pulley and 60's to see what happens.
Old May 12, 2007 | 06:53 PM
  #56
RickZ28's Avatar
On the ZZP sites they say you can run up to 2.85 on stock injectors if you have a complete exhaust setup. Link
So there should be no problem to run a 2.8 on stage 2 with a complete exhaust setup right ??
Old May 13, 2007 | 05:50 PM
  #57
RickZ28's Avatar
bump !!
Old May 13, 2007 | 05:57 PM
  #58
Mikey851's Avatar
Originally Posted by RickZ28
bump !!
I would not use the stock injectors on a 2.8" with a full exhaust. Why not get some 42.5lbs with full exhaust. It's not like the injectors are so expensive that you should cut that corner.
Old May 13, 2007 | 08:02 PM
  #59
p7x's Avatar
p7x
you can push the limits if you'd like and probably run for a while but IMO its gonna mean BOOM. I was maxing out the 42's everytime I went passed 6000rpm with my 2.8
Stock injectors are maxed out with stock pulley
2.85+ = 42's
2.8- = 60's
Old May 13, 2007 | 08:16 PM
  #60
Blown 4-banger's Avatar
I vote that we boycott threads like this! Just ignore them, and they'll go away!
Old May 14, 2007 | 10:24 AM
  #61
Zooomer's Avatar
Supporting Vendor
I'm going to edit that post with some information we have now about this engine and what is safe. I would not run a 2.85 on a stock pulley unless you plan low shift points.
Old May 14, 2007 | 10:28 AM
  #62
Originally Posted by vextc05
i just got a car with these mods. Does anyone have this combo and have u experienced any problems with it??? would love ur input. Im thinking about just replacing the pulley with a 2.9 pulley to be on the safe side. whatcha think?
do you know if the previous owner was a member of the site?
Old May 14, 2007 | 10:34 AM
  #63
BLKblurr06's Avatar
I have been running the 2.85 on stage tune with no problems, b4 I slapped it on I did a search on the net to see where I was in relationship to sea level. If you are close to see level I wouldnt drop below a 2.99 just to be safe. If you want more power look towards exhaust mods and a tune
Old May 14, 2007 | 10:47 AM
  #64
SSdan's Avatar
I live at sea level, literally. After about 6200rpm, my car does INDEED go lean really hard. I try shifting at 6000 now to be safe.
Old May 14, 2007 | 11:04 AM
  #65
BlurpleSS's Avatar
to the idiot that said that you can run a 2.85" on stock injectors... you're totally wrong. the stock injectors run over 100% dutie cycle on the stock pulley... on the 2.85" you'll run SUPER Lean & blow your pistons up.
Old May 14, 2007 | 11:10 AM
  #66
STG2BALT's Avatar
I have a 2.85 and #42 injectors with stage 2 tune and ive been runing decent a lil rich but thats about it
Old May 14, 2007 | 11:55 AM
  #67
BlurpleSS's Avatar
I think the guy was refering to the 34# injectors with a 2.85... which is absolutely stupid...
Old May 14, 2007 | 01:27 PM
  #68
Zooomer's Avatar
Supporting Vendor
I looked at our web page. It didn't say you could run a 2.85 on stock injectors. It said that you could run a 2.85" WITH injectors and that we didn't recommend smaller. I've edited the page to remove confusion.
Old May 14, 2007 | 01:37 PM
  #69
Gory's Avatar
I have run stage 2+2.8 pully for 18k miles very very hard miles and my car runs fine.
Old May 14, 2007 | 02:09 PM
  #70
BlurpleSS's Avatar
I don't think there's anything wrong with 42.5's and a 2.80. you max out the injectors, but it's not dangerous.
Old May 14, 2007 | 02:27 PM
  #71
CHARGDSS's Avatar
2.8 + 42's = knock knock for me
Old May 14, 2007 | 02:30 PM
  #72
blk06ss/sc's Avatar
i got stage 3 tune 2.7 with 42's and its been fine for months now with full exhaust with just a high flow cat
Old May 14, 2007 | 03:00 PM
  #73
BlurpleSS's Avatar
I think 2.7 is in need of 60's... but not the 2.8
Old May 14, 2007 | 03:20 PM
  #74
vextc05's Avatar
has anyone had any problems with their CEL flashing for a few secs and then going off?? It happened to me this morning, scared the living crap out of me
Old May 14, 2007 | 03:29 PM
  #75
p7x's Avatar
p7x
When I was running S2 with 2.8 I got 2 seperate LEAN codes.
