is anyone running with a 2.8 pulley and 42.5 injectors? Any probs???
Old May 7, 2007 | 05:17 PM
SSdan's Avatar
Originally Posted by Area47
trust me, im not new at this.
im going to find out the exact IDC tomorrow {saturday} if everything is cool. the 2.8 goes back on. the bad thing is, i have the 3.0 pulley pulling just as hard right now, if not better up top.
again, it also could be the wideband im using freaking out. which will be double checked tomorrow.
as far as the duty cycle. im using the config file that denny uses on this hp tuners logger as well. it could very well be wrong. i don't think anyone has taken the time to stick a tech2 on the car to see how gm reads things.
but we are about to find out!
I would love for someone to do this. It would clarify A LOT of things.
Old May 7, 2007 | 05:50 PM
Boost Fr33k's Avatar
this is an argument that will never end!!!! 42lbs & 2.8! ahh!! well im not adding to the dilemma but my friend blew his motor running this set up, but then again ive noticed that hp gains and engine realibility is never the same with lsj's. some ppl run fine and some people blow up.
my suggestion, like many, dont over do your injectors.
Originally Posted by RickZ28
I'm running the 2.8 setup for a year now and no problems, but you're starting to scare me now with the IDC thing
injectors duty cycle: GET SCANNED!
Last edited by Boost Fr33k; May 7, 2007 at 05:50 PM. Reason: Automerged Doublepost
Old May 7, 2007 | 06:06 PM
Area47's Avatar
Rent me! per hour
i did a 2nd gear pull, with the tech2 on the car. pulled 17 m/sec in a 20-70 run.
on stage 2.
now, not much of a load like 3rd or 4th gear, but you get an idea.
this was also with my stage2-100 octane map, so there is less fuel in general, but not as much as one would think.
17.0 comes out to be about 67%
Old May 7, 2007 | 06:30 PM
RickZ28's Avatar
But the GM stage 3 has a 2.8 pulley and no bigger injectors, does this mean that stage 3 is bad
Old May 7, 2007 | 06:40 PM
chipsgt's Avatar
Its not really a 2.8 pulley.... its bigger than that.
I dont remember the exact size, but it was actually closer to a 3.0
Old May 7, 2007 | 06:43 PM
Mines_Better's Avatar
i ran a 2.85 with stock injectors for awhile until i received my tune and 60's. i didnt have any problems whatsoever but i prolly got lucky. who knows...
Old May 7, 2007 | 06:54 PM
BlurpleSS's Avatar
yeah, definatly lucky! haha!
Old May 7, 2007 | 07:04 PM
RickZ28's Avatar
You are right stage 3 76mm = 2.99in
Sorry my mistake
So i'd better run the stage 3 pulley instead of the 2.8 right ?
Old May 7, 2007 | 07:08 PM
SSdan's Avatar
on stage 2.
So that means like in your previous post where you and I agreed 42lb injectors WILL support a 2.8 pulley?
Old May 7, 2007 | 07:14 PM
Area47's Avatar
Rent me! per hour
im not going to say yes, but im not going to say no. i don't want to be "that guy", that says "sure it's fine!"
then get flamed like none other. have i risked my car? yulp. not a big deal to me.
let me get some more time with a tech2 before i give a concrete answer.
Old May 7, 2007 | 07:27 PM
  #36
SSdan's Avatar
We're thinking on the same page!
Two things I do believe one needs when you run a 2.8 and 42's, colder plugs and a tune.
Old May 7, 2007 | 07:36 PM
  #37
Area47's Avatar
Rent me! per hour
i change pulleys so much, i just keep the 7e's in the car, and the laptop readily accessable to change tunes.
just a heads up kids, running too big of an injectors is almost as bad as running too little.
you can only take so much fuel out
Old May 7, 2007 | 07:55 PM
  #38
SSdan's Avatar
Exactly.
I was reading over on another board, some believe that using 60lb injectors are actually STARVING the motor of fuel, and the reason why it is always piston #4 is because it is also furthest away from the entrance feed of the fuel rail.
Source of the theory; maxed out fuel pump.
Think about it, you guys are using injectors with a flow rate of nearly TWICE the rate of the stock injectors.
I don't believe that GM would use a fuel pump that would support double the flow rate during production.
Old May 7, 2007 | 07:59 PM
  #39
p7x's Avatar
p7x
Exactly.
I think the fuel pump is capable of handling the 60's its the fuel rail itself that is the limitation. As well I would rather be running injectors that are too big than too small, just my 2 cents.
Old May 7, 2007 | 08:01 PM
  #40
SSdan's Avatar
So, if it's the fuel rail itself, what is causing it to be limited? Maybe cause the fuel pump can't keep up?
Old May 7, 2007 | 08:05 PM
  #41
SSrambamSS's Avatar
is it safe to run a 3.0 inch pulley on stock injectors?!? if no why?
Old May 7, 2007 | 08:06 PM
  #42
p7x's Avatar
p7x
physical space, I remember reading about this exact issue and zinner and wopontour had a discussion about the actual size of the rail. Saying it is restrictive. Increasing the fuel rail size should help get fuel to #4 faster without increasing fuel pressure.
because the IDC for the stock injectors on stock pulley is averaging above 120% from thelast 5 logs of stock SS S/C's that I have seen.
Old May 7, 2007 | 08:08 PM
  #43
killah_thug08's Avatar
so the bottom line is its safe to to have 2.8 wit 42s wit cooler plugs and a tune or not
Old May 7, 2007 | 08:09 PM
  #44
SSdan's Avatar
Read the thread moron.
Old May 7, 2007 | 08:11 PM
  #45
p7x's Avatar
p7x
IMO no...you can get a leaned out tune to get ur IDC down but thats a bomb waiting to go off. When I had 42's and a 2.8 anytime i went past 6000rpm i was maxing out my injectors and running leaner than I should have.
Old May 7, 2007 | 08:12 PM
  #46
SSdan's Avatar
I read that also, but I still believe it has something to do with the fuel pump.
There is a guy trying to fabricate his own fuel rail, where the fuel inputs the rail between cylinder 2 and 3. What he is trying to do is distribute it more directly in the middle. Although cylinders 2 and 3 will still get the most fuel, the theory is a possible solution to our problems.
Old May 7, 2007 | 08:14 PM
  #47
p7x's Avatar
p7x
more than likely it will help, Im just pissed off that everytime I add a lil power seems i gotta change the little things that should be able to handle more power like the pump or rail.
Old May 7, 2007 | 08:23 PM
  #48
Psykostevo's Avatar
Originally Posted by an0malous
and did you realise that HP tuners doesnt log our IDC properly without altering some of the variables?
You honestly think GM would sell a kit and warranty it, right from GM performance devision.....with 117% IDC?
They sell you a kit and warranty it with 4-5* of KR, so yeah......they are retarded depending on who you ask.
The GM injectors are not as good as the Bosch style injectors that are in the Intense kits. The IDC is higher from MY experience on the GM stage 2/3 injectors than on the 42.5#'s from elsewhere. But I can't speak for everyone.
FUELRAILS will OWN you down the road. Damn Fuel Pressure Probs!
Old May 8, 2007 | 11:53 PM
  #49
SSdan's Avatar
Let's bump this back to the top.
Old May 9, 2007 | 11:28 AM
  #50
Area47's Avatar
Rent me! per hour
2.8 + 42.5's = good for about 2 weeks.
the gm injectors can't handle it. pure and simple.
hell they can barely handle the stage 2 crap.
i wonder if there is a way to bump up the rail pressure. i know that the ecm controls that side of it. it doesn't give us the power in hp to do it.
