is anyone running with a 2.8 pulley and 42.5 injectors? Any probs???
Old May 14, 2007 | 06:45 PM
  #76
BlurpleSS's Avatar
Originally Posted by vextc05
has anyone had any problems with their CEL flashing for a few secs and then going off?? It happened to me this morning, scared the living crap out of me
engine misfires maybe. go to autozone and get it checked out.
Old May 15, 2007 | 04:29 PM
  #77
l337m4573rpyr0's Avatar
I've been running the 2.8 with my stage 2 for 10 months now. I haven't had any problems - But I also don't make a habit of going past 5k rpm. I getting 60lb'ers and a tune this summer anyways so I don't have to worry. Too much research and documentation out there not to.
Old May 15, 2007 | 04:54 PM
  #78
zinner's Avatar
Moderator Alumni
Your AFR's are plenty safe (11.5-12) on a 2.8 and 42# injectors up to a 7k redline.
If you look at the several I blew up my engine threads you will see most of them are running bigger injectors and they are running a richer AFR ( 10 -11 )... I haven't read any threads where a piston popped because of a lean condition.... Just a thought...
Old May 15, 2007 | 06:23 PM
  #79
ebristol's Avatar
Originally Posted by SSpartan
I have been running the 2.79 and my GM stage tune for a while with no negative repercussions.
I went to the now out of business VT racing for dyno time at 3 different times.
once stock
once with stage 2
once with my stage 2.79 (as I call it)
all in all it ran very rich with stage 2 on it. When I slapped the 2.79 on it leaned it out a bit.
when I look at my dyno charts right now to me it looks like the tune is attempting to balance the a/f in stages. it starts a little lean then adjust, finds that it is still lean then adjust a third time where it ends up a bit on the rich side.
What where your dyno results with the 3 different runs?
Old May 15, 2007 | 10:56 PM
  #80
cblt12's Avatar
damnit this thread is making me rethink my plans... i may keep my 42's and go back to the 2.8 w/ a couple of cooling mods untill i drop to the 2.6 or 2.7
Old May 15, 2007 | 11:17 PM
  #81
SSdan's Avatar
I see your located in cali, and from your sig pic it looks like damn near you live at sea level like me. I run it perfectly fine until 6grand, then the AFR starts to climb back up at a slight level. It ends up somewhere in the 12's right before the redline hits.
I run the Stage 2 injectors + tune, Injen, and a catback exhaust.
Old May 15, 2007 | 11:21 PM
  #82
cblt12's Avatar
then hopefully the 60's should be good w/ the 2.8... i only have a muffler right now so when i get some more exhaust mods i will go w/ a smaller pulley.
Old May 16, 2007 | 12:10 AM
  #83
RBC's Avatar
RBC
I wish I had some input of value to add to this but I don't. The only thing I can say is if you are one that believes it is not safe don't run it. For the people that believe it is safe, then run it. All in all if something goes wrong put the stage 2 pulley back on and use the warranty you bought the kit for. Just M.O. try not to take offense.
Old May 16, 2007 | 01:01 AM
  #84
BlurpleSS's Avatar
everyone i know who's blown their motor is because of being lean in the 4th cylinder. but it's always the big injector, small pulley guys... I haven't heard of anyone here in AZ who's blown their motor with a 2.8 & 42's
Old May 16, 2007 | 02:07 AM
  #85
Blown 4-banger's Avatar
Thats because they are not running lean like everyone thinks they are. Just because the injectors are at or over 100% IDC doesn't mean they are lean, it means the injectors are working really hard to maintain a fairly rich AFR. The are also not running high amounts of cylinder pressure and heat like the 2.5-2.6/60s guys are. Poor coolant flow to cylinder 4 is a major problem and high IAT2 is fatal in most cases.
Old May 16, 2007 | 11:31 AM
  #86
Area47's Avatar
Rent me! per hour
i will say this one time.
just because you are runnin 11.8 a/f, seeing no knock does NOT mean it is safe.
what is the cylinder temps? dunno? hmmmmmmm
Old May 16, 2007 | 05:30 PM
  #87
BlurpleSS's Avatar
yeah, 11.8-12.0 is NOT a save AFR...
Old May 16, 2007 | 05:35 PM
  #88
Yes it is. That is a perfectly safe AFR, hell a lot of NA guys run 13.x AFR. Cobra guys run 12-12.5 AFR. 11.8-12 AFR is not an unsafe AFR, if people are blowin up while running that AFR its something with the engine, not AFR.
Old May 16, 2007 | 05:45 PM
  #89
distillion's Avatar
blown, i know you had quite a bit of cooling mods done, im puzzled on why you popped?
Old May 16, 2007 | 06:29 PM
  #90
Area47's Avatar
Rent me! per hour
Originally Posted by denny
The REAL truth is this: Nobody knows 100% for sure what are making the engines blow piston number#4.
It would be nice to have some stats from all of them at the time it happened. Maybe we could narrow it down......
no one knows because they haven't a clue what the cylinder temps are.
this is why the egt is so important!!!!!
if your a/f starts to climb the closer you get to 7k this is a sign that your injectors are going static. mine is doing the same thing.
2.8 and 50 lbers would be peachy.
Old May 17, 2007 | 04:22 AM
  #91
Gory's Avatar
On most boosted motors 12.8 is about the max you want to go but there are many many many factors such as: air temp, octane/gas quality amount of boost and combustion chamber design. On any motor you really dont want to run ritcher than 11:1 because then you are washing down the cininder walls and your EGTs skyrocket.
I have beel looking at my spare fuel rail and there is a problem on the inlet. it almost completly blocks off the first injector im not shure if that is cilinder #1 or #4
Old May 17, 2007 | 08:00 AM
  #92
distillion's Avatar
12.8 is a lil high for boosted cars imo.
and your right about the fuel rail, i belive the blockage is at number 4.
Old May 17, 2007 | 11:10 AM
  #93
Area47's Avatar
Rent me! per hour
um, 12.8 is awesome.
for the LS1 family motors. not forced induction.
Old May 17, 2007 | 11:44 AM
  #94
Gory's Avatar
Like i said 12.8 is relative and if you notice i said that is max on a boosted car. Most NA guys run about a 13.5. Oh the other thing i thought about was if you run to rich there is a chance of burnning your exaust valves or getting them so hot that they will cause detonation .
Old May 17, 2007 | 12:56 PM
  #95
Area47's Avatar
Rent me! per hour
most NA honda guys run 13.5
the rest of the world runs 12.8. who ever told you that 12.8 is fine for a boosted application is on crack. i never ran that in my gxp on bottle. it was sitting at 11.8 a/f
hell my tsi ran 12.1 with water injection, the gsx ran 11.3.
denny, it apprears the only cylinder in danger is the number 4.
i ran out of money, so i can't give you concrete answers on egt temps yet
Old May 17, 2007 | 01:14 PM
  #96
Area47's Avatar
Rent me! per hour
Awesome an old DSM guy
Yeah I know about number#4 I just talked to Al "WITT" he told me to add the EGT on number#3 for an accurate reading of them all.
Im going to order one today, I really need to know whats going on.
Damn its getting expensive these mods.....lol....
Ah well!! money spent towards prevention is better then money spent fixing.
yepo, 300 to the tire on a 14b, and 403 to the tire on a 16g.
wheeeeeeeeeeeee
the tsi never broke, the gsx was broken every two weeks like freakin clock work.
anyways, i was just going off my dsm knowledge of putting the probe in number 4. what really sucks is we don't have full control over individual cylinders, such as timing and injectors. that would solve a lot of problems
Old May 17, 2007 | 01:24 PM
  #97
Gory's Avatar
OK LIKE I SAID BEFORE 12.8 IS about The MAX! THE higest you can possibley go.
Most na cars dont like lower than 13:1 they load up and dont acelerate as fast.
Old May 17, 2007 | 07:20 PM
  #98
BlurpleSS's Avatar
NA can run a higher AFR than Forced Induction... but for the supercharged cobalt, 11.8 is not safe. Otherwise, Cameron, you would still have a running car! I guarentee your mods with a 11.0 AFR would be still running today... but since you were 11.8, you blew your motor up.
11.0-11.4 max for the Cobalt IMO.
Old May 18, 2007 | 03:09 AM
  #99
RoelSS's Avatar
Those 42lbs injectors are for the pulley they came with and the stage 3 pulley 77.9mm vs 76mm, not much of a difference. I had the 2.8 with stage 2, but the car ran like crap. Limp mode, felt sluggish after hitting the rev limiter, etc...
If you want to be safe, use the 60lbs and tune them in with HP Tuners. The results are much better, as some of the guys here claim. Check out tag racing, New Era, etc...
Hope this helps
Old May 18, 2007 | 03:13 AM
  #100
1gmfanatik's Avatar
You CAN tune the car to run well with the 42's and a 2.8 or 2.79" pulley. BUT...Every car is different, so it will depend on how that car handles the injector/pulley combo.
