ARP Head Stud Install Question
Just wondering if this is correct for the ARP head studs
ARP moly lube on the studs, then hand tight in the block
Then nuts tourqed to 75 ftlbs
Or is that not correct.
Thanks guys.
Thanks guys.
yeah it does, but the guys that are doing it with me think the hand tight bit is a little weird, so i wanna get some first hand knolage of someone thats already done them.
Yes the lube on both ends and they state if you want it permanent use lock tight on the thread going into the block. Check what torque specs they state for your application, should be in the box. I thought it was 80 ft lbs for the moly lube. Someone in a thread was just saying peoples first mistake with head studs is over tightening..
