ARP Head Stud Install Question
Old Oct 13, 2009 | 10:45 PM
MikeyB's Avatar
Just wondering if this is correct for the ARP head studs
ARP moly lube on the studs, then hand tight in the block
Then nuts tourqed to 75 ftlbs
Or is that not correct.
Thanks guys.
Old Oct 13, 2009 | 11:03 PM
SCcobaltSS's Avatar
It should have instructions for installation. Mine states to use the Lube and tighten to 80 ft lb in three equal steps or to 85 ft lbs with 30wt oil for 200,000 psi.
Old Oct 13, 2009 | 11:05 PM
MikeyB's Avatar
yeah it does, but the guys that are doing it with me think the hand tight bit is a little weird, so i wanna get some first hand knolage of someone thats already done them.
Old Oct 14, 2009 | 12:29 AM
Tennpenn83's Avatar
hand tight is correct for the studs. then for the nuts, go in 3 steps, increasing torque by 1/3 each time (30/55/85)
Old Oct 14, 2009 | 01:07 AM
MikeyB's Avatar
Okay cool, so you put the moly lube on both ends of the threads right? block and nuts and end at 85ft lbs?
Old Oct 14, 2009 | 11:21 AM
SCcobaltSS's Avatar
Yes the lube on both ends and they state if you want it permanent use lock tight on the thread going into the block. Check what torque specs they state for your application, should be in the box. I thought it was 80 ft lbs for the moly lube. Someone in a thread was just saying peoples first mistake with head studs is over tightening..
Old Oct 14, 2009 | 07:46 PM
damien's Avatar
I used the lube they supplied, and tightened to about 85ft lbs in about 5 steps or so.
Old Oct 15, 2009 | 06:53 AM
2K5SS/SC?'s Avatar
I would put the studs in the block to at least 10ft lbs instead of hand tight. Just something I learned from a previous experience with the whole "hand tight" thing.
Old Oct 15, 2009 | 08:01 AM
damien's Avatar
Or you can put them hand tight and then using an Allen key tighten them to snug.
Old Oct 15, 2009 | 04:18 PM
YzRider452's Avatar
Do the headstuds go into the stock holes, or do you need to drill and tap them?
Old Oct 15, 2009 | 06:16 PM
damien's Avatar
Stock holes
Old Oct 16, 2009 | 04:16 PM
YzRider452's Avatar
sweet thanks man.
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
