avg. WHP gain on ported head?
You will have us beat on torque for sure. I have about another 1000 miles before I'll even think about a dyno. I need to get back tuning again. It has been a while since I was well-versed in HPT.
It sure seems to. They are not much longer than stock LSJ but the motor is undoubtedly smooth. There is not as much vibration from the balance shaft delete kit as I thought there would be. In fact, if you didn't know they were deleted, you likely wouldn't be able to tell.
What is stock length C2C? If I remember correctly, the Eagle rods are 5.765" but in any sense, they were mated with custom Diamond pistons for the smaller wrist pin, the bigger bore, and the higher compression.
A ported head is always a plus but there r plenty of other ways to get more out of Ur car. On a relatively stock car its proly not worth the trouble to swap the head just for a ported one. Now if u were gona through a mild set of cams in with some springs that would make it more beneficial.
I hear you and the biggest variable for me is the odd application on the sand. Its hard 45 minute runs chasing the guys with V8's with twice the HP. It has just enough top end power because its lite but I question is if my setup with the 2.9 is conducive to beating it wide open like I have too on the hills or could I help it.
A lil 50shot would really wake that thing up.
Wat r u doing for a pcm and wiring. Im looking into building a ecotec powered jet boat. I thought about gettin a l61 out of a cavi then build it and SC it.
MEFI 4A ECU
