avg. WHP gain on ported head?
Old Mar 13, 2010 | 08:15 PM
  #176
Tennpenn83's Avatar
that's very impressive numbers there. thanks for taking the time to do this.
Old Mar 13, 2010 | 08:26 PM
  #177
qwikredline's Avatar
hey tennpenn you and me we just have to quote darkmanx numbers. we thus are hero's and didnt have to spend the dyno money....
Old Mar 13, 2010 | 08:28 PM
  #178
recklessactn's Avatar
wow this thread became actually useful lol good stuff dark
Old Mar 13, 2010 | 08:31 PM
  #179
Tennpenn83's Avatar
nobody's going to know you don't have a ported head unless you tell them...
Old Mar 13, 2010 | 08:32 PM
  #180
I gotta ported head....lol
Old Mar 13, 2010 | 08:37 PM
  #181
Tennpenn83's Avatar
so do i..
  #182
dark you said your head was ported by a shop? how aggressive was it?
Old Mar 13, 2010 | 08:44 PM
  #183
Darkmanx's Avatar
compaired to what ? how do you determine how aggressive a heads ported? i just dropped it off and told him my goals and told him i want my power through my whole power band and he did what he did . sorry but i didnt just find a porter and drop my head off i researched the guy i sent him the zzp flow before and after numbers and every other numbers and told him what they where doing , sent him the build book all that crap yada yada , took about 5 months then i dropped it off.
Old Mar 13, 2010 | 08:51 PM
  #184
ahhh very nice, was just curious to how the job went down thats all :-P
Old Mar 13, 2010 | 09:01 PM
  #185
ItalianJoe1's Avatar
Head looked nice. Minimal bowl work, but the ports were nice and even looking, very smoothly blended. Deck finish was very nice as well, chamber edges were super sharp, peeled half the skin off my palm at one point in the job.
Glad to see you making great power X, keep it up. Down to install pistons whenever you are ready.
Old Mar 13, 2010 | 09:03 PM
  #186
Darkmanx's Avatar
listen to this guy , he inspectected the head more than me , it was just sitting in my closet . I think when im ready for some pistons im gonna do 10.1 compression
Old Mar 13, 2010 | 09:05 PM
  #187
Pretty sure thats what I had, or 10.5, don't recall, but I only really did it to offset the cams. I dunno if you will gain much from it, but it can't hurt.
Old Mar 13, 2010 | 09:19 PM
  #188
Darkmanx's Avatar
i just figured with higher compression i would have room to work i would rather knock at 15 degrees of timing and know if i figure out how to stopp the heat ill make more power than be stuck at 25 degrees of timing with no where to go.
Old Mar 13, 2010 | 09:21 PM
  #189
Very true. I forget about the higher octane effect of the E85.
Old Mar 14, 2010 | 05:14 PM
  #190
Speedytec's Avatar
While discussing head porting:
This is the exhaust manifold of a BTCC engine. (= L61 with 2.0l displacement for British Touring Car Championship)
Had 264 (engine) bhp in NA form, but interesting to see how they used the SAI ports for better exhaust flow. Any expert opinions on this?
Old Mar 14, 2010 | 05:22 PM
  #191
those are using the egr ports for the L61 that exist on the LSJ port? Wonder what they do to the head, for NA i guess it must give something otherwise they would not do it...sor s/c I dunno. I thought of welding them shut, but decided it wasnt worth the effort. i got no expertise in this....
Old Mar 14, 2010 | 06:50 PM
  #192
Speedytec's Avatar
Yep.
Do'nt know how the head porting looks (yet), but this manifold at least shows that they used the EGR/SAI ports for flow.
And these BTCC guys got some 285bhp from a 2.0l NA Ecotec engine, so they knew a bit what they were doing...
Old Mar 14, 2010 | 07:14 PM
  #193
Originally Posted by Speedytec
Yep.
13:1 cr etc...its doable...
Old Mar 15, 2010 | 10:14 AM
  #194
ebristol's Avatar
Very Nice results. Those are the results I think most people were expecting.
Old Mar 15, 2010 | 07:03 PM
  #195
Darkmanx's Avatar
The final numbers in STD ARE UP. 364/303
Old Apr 9, 2010 | 11:26 AM
  #196
alanoo's Avatar
Except when the rules are 11:1 CR, 11mm valve lift and 8500 rpm max (+ single TB)
(and the last spec is actually 10hp more, very close to 300hp)
Old Apr 9, 2010 | 11:57 AM
  #197
ralliartist's Avatar
^damn
Old Apr 9, 2010 | 01:37 PM
  #198
Speedytec's Avatar
Hi Alanoo,
You are quite familiar with the Opel/Vauxhall BTCC stuff, so maybe you have a pic somewhere that shows something of the exhaust porting done on those heads??
(Was already wondering why those fancy carbon inlets I saw all worked with a single (60mm Jenvey?) TB...)
Old Apr 9, 2010 | 03:54 PM
  #199
alanoo's Avatar
Nop, saw one late head (2008), but have no pic
Late heads didn't port upto the SAI ports, just had the manifold bolts moved to get some more room for bigger primaries
Single 60mm TB is reg limited too
Old Aug 27, 2013 | 09:15 AM
  #200
skateerkid99's Avatar
Originally Posted by chevysssc
over 9000 hp? u must be thinking of an airbox mod. im actually talking about a real mod.
no i think he is thinking about the vtec swap!
