avg. WHP gain on ported head?
John, we are on the same page. We are arguing the same points. You didn't post anything I didn't already know. I've made the same arguments before on this forum and on the redlineforums.
I wasn't slanging the GMR head. You are just trying to make me look like a jackass now, which is fine because sometimes I can be one. But the truth be told, the GMR head still isn't the most aggressive port job out there. It's more aggressive than I thought, yea, but still not the most aggressive.
I might add, that my head.... Billa as stated was unpolished at the time. Granted in comparison it doesn't seem to be as agressive either. But if you compare old numbers to new numbers as is really needed for a apples to apple comparison you will see the percentage it gained over stock, or whatever your numbers flowed on THAT flowbench. I'd love to see what a gmr looks like, john, could you send me some detailed pictures?
Btw what is the total lift after the ratio is added?
ferrea custom valves(about $600) and 80lbs springs($550) made in the same metal that gm uses in their race cars. this is where i got it done http://www.headgamesmotorworks.net/
like a valve that will never snap, will never take out my sleeves, head, piston, and will never burn up? its obvious you are now trying to keep your rep. intact. and my valves cost around $600 only $200 more than TTR's Ferreas. small price to pay for a valve that will never cause me any trouble in the future.
Do you guys keep on missing the part where he said the work is being done for free basically by the shop and by his family? Look all and all yea its overkill on an lsj unless hes gonna turbo it down the road and make serious horsepower, but why is this thread getting bloated with bs when the question was what were your avg whp gains when you put on you ported head... and like qwick said no one has posted a before and after comparison (not known) so now hopefully we can get some b/a numbers in the future.
I think all everyone was saying that is the squeaky hinge gets the oil, if something in our engines hasnt been known to be particularly troublesome why replace it with something overkill? Just my .02
Absolute flownumbers say nothing (same with dyno's):
Billa's exh @400 lift:
stock = 133, ported = 173.3 => Gain = 130%
MR2 race exh @400 lift:
Stock = 147, ported = 199 => Gain = 135%
Qwik GMR ported exh @400 lift:
Stock = 175, ported = 220 => Gain = 126%
Ralli exh @400 lift:
Stock = ??, ported = 185 => Gain = ??%
(I got one of Qwik's heads, because it has a decent gain over stock and I did not want too big ports to maintain the gas speed. And because it was a good deal..
Yup Speedytec is on it. Good math skills and smart buy....now re read Tyler Omega_5's quote and it should start to make sense. And forget about the cost considerations and whoever has expensive valves. Just be patient and wait for EBristol to confirm what GMR already found out...
thank you for paying attn. to what you read.
i have personally cranked more than 1700 degree's out of the port. now what does this equate to in actual cylinder temps before the intake valve opens?
Agreed. but better than sticking your dick out the window...Oh wait....maybe not
Oh hi Pamela...no... just waiting for you. Go ahead... Hmm thats nice....hey! who pushed the window lift button! that hurt!...sorry Pamela....maybe we should go somewhere more...private....[/QUOTE]
lol
lol
[QUOTE=Area47;4746173]VALVE CONTROL. if you melt a valve. you have tune issues. period. i give two ***** about my rep. this is the internet. QUOTE]
Valve control? i have 80# Ferrea dual springs, no problem there. and these pryomet valves are good past 2700* overkill maybe, but i will not have to replace them if i have a tune issue. i plan on keeping this car for a long time and wont ever have to touch the head again no matter how much boost and heat i throw at it down the line.
I will update this thread later on with some numbers, the shop should have the head on the car by the end of the day and then it goes on the dyno. Here is what you will get.
Stage 2 setup and tune, cold air intake, exhaust, blah blah, stock head 230whp
Stage 2 tune with 2.8 pulley and 60lbers *only thing changed in tune is the injector settings* With the ported head.
My tune + 2.8 pulley 60lbers, ported head.
It's not 100% a vs b but fairly close. I mean the only thing changing is from the stg 2 pulley to the 2.8 and then non ported head to ported head. Then in the end I wanna see what just my tune will pick up.
Hopefully this will help the community see that decent gains are possible not only from tuning which we already know, but also from a ported head. Numbers should be up by 5:30pm today along with the graphs etc. I'm not going for a world record here as this is a CLIENTS car and not my own, it also doesn't have meth so don't expect 300whp.
eh its still a couple of variables that are changing, i personally would rather have seen before after a to b.
when we do my head thats how its going to be setup with non ported head, dyno, pull car off, put it in side of shop, pull head off, port + valve springs, slap back on, dyno again. only variable is going to be the weather changing from a to b which wont be significant
for zach if you want specifics, why not run it with the stage 2 stuff after the head goes on then install the other. shouldn't take but 30-45 minutes.
as for the other post, yes we know around about what all 2.8's run so we would have a general idea of the gains
good thanks
good thanks
Last edited by qwikredline; Mar 9, 2010 at 12:06 PM. Reason: Automerged Doublepost
