Bad Coil packs?
Bad Coil packs?
I keep getting a CEL every now and again ( been getting more frequent ) saying multiple cylndar misfire. Car runs fine, idles fine, no visual or hearable problems. Im thinking maybe a coil pack is going bad? spark plugs are changed every oil change. any ideas or help is appreciated
nope theres no tapping or any other kind of noises, and they are about 1/4 past hand tighten, i usually get them tight and just a little tug once and i call it good.
You don't have those ebay boot springs do you?
i have the same problem. its not the coil packs, plugs, injectors. check where the bost line runs 2 the little black rectangular box directly 2 the right of the engine where 1 line runs in 1 side then another line runs out the back. if u have a buddy try swapping out map sensors also that may be ur problem
some of the things gm does im like ah sweet thats easy to change, like the rear suspension on cobalts, other things you wonder what the hell they were thinking ya know
Iceberg
Sep 29, 2015 12:33 PM
