bad vibrations with ottp stg 2 mounts? solution!
Old Dec 6, 2011 | 09:20 AM
willdrew's Avatar
Now that is just being lazy.
You shouldnt have loosned the upper mount it's self.
Not saying it's bad, but it wasn't needed.
To recap on everything for anyone that may still be confused in this thread:
When installing rotated mounts, or trans mounts in general....
Loosen the 3 bolts on the upper engine mount, and re-torque to 37 lb-ft.
Sweet! I Have the TTR engine mount. I didn't loosen those 3 bolts since i installed my LNF mounts and vibes are still there. Hopefully when i do this majority of them go away.
Old Dec 6, 2011 | 09:25 AM
keiserX13's Avatar
I'm not but i know a lot of users are
Wasn't thinking and did that the other day thinking they where the ones you were referring to
works amazingly
Old Dec 6, 2011 | 09:33 AM
works amazingly
glad u did it. i know i was hating the vibs, now i practically forgot i have em
Old Dec 6, 2011 | 03:50 PM
arellano201's Avatar
dumb newb
question, but do i need to order jut one ottp tranny mount or does it come with a pair? or do i just need one?
Old Dec 6, 2011 | 04:13 PM
keiserX13's Avatar
Originally Posted by arellano201
dumb newb
for OTTP Stage 1 is one mount Stage 2 is two mounts
ZZP are separate
TTR is a pair
Old Dec 13, 2011 | 03:15 PM
ZZP are separate
TTR is a pair
Thanks! So just with the ottp stage 1 one mount is all I need right?
Old Dec 13, 2011 | 03:25 PM
its best to get stage 2 from ottp...
the 'stage 1' is the rotated mount at the front
stage 2 includes that mount and a spacer to make up for the engine rotation that goe on the bottom of your engine on the frame
Old Apr 20, 2012 | 09:59 AM
michiganfootball911's Avatar
Do i need to support the engine when i re torque the engine mount or the spacer bolts?
Old Apr 20, 2012 | 10:00 AM
NO. make sure u read this thread though because i just wrote it, didnt rly know what i was doing
Old Apr 20, 2012 | 10:03 AM
Thanks. Ya im going to re torque the engine mount first. Hopefully that will do the trick. If not ill try the spacer bolts.
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Sep 27, 2015 08:53 PM
