Badmab or zzp mid combo?
Old Jan 19, 2012 | 07:43 PM
Blowncavy's Avatar
I was thinking of getting rid of my cobalt so I sold some of my stuff. Header, wheels, coue small things. I was gonna sell my downpipe (zzp) and put all stock on aswell. But now I think Ima keep it longer then what I thought. So my question is, should I slap the bad mab to replace stock header, or just sell downpipe and get the zzp mid combo?
Does the zzp combo make more power then the bad mab setup? Sound better? Is it really worth it, or should just get badmab? Thanks
Old Jan 19, 2012 | 07:45 PM
TurboTechRacing's Avatar
Did you ever look into the Vibrant header and downpipe kit?
Old Jan 19, 2012 | 07:48 PM
Blowncavy's Avatar
Never did. Are they like $6-700.00?
The zzp cost like $370.00, so that's why I was gonna do that.
Old Jan 19, 2012 | 07:50 PM
They are not that price on our site... Plus it includes a downpipe, quality is the best too.
Old Jan 19, 2012 | 07:52 PM
Blowncavy's Avatar
Ill check the site out. Zzp comes with the dp also, everything for $370.00.
Not really wanting to put more money into car. I have an sc cavy that has pacesetter setup and love it though
Old Jan 19, 2012 | 07:53 PM
You can get a pacesetter header also for the cobalt, we carry them, if you want to go even less $
Old Jan 19, 2012 | 07:55 PM
Blowncavy's Avatar
You have the downpipe for them? Or can I just have it welded to my zzp downpipe somehow?
Old Jan 19, 2012 | 07:57 PM
They come just like to one for your cavy did... I am sure you can modify the ZZP downpipe you have to fit to it.
Old Jan 19, 2012 | 08:02 PM
Blowncavy's Avatar
Ill just get the pacesetter and have it welded to my dp.
Also how big are the primaries?
Old Jan 19, 2012 | 08:03 PM
Order on www.TurboTechRacing.com
If you need help locating it on our site let us know. Thanks!
1.75" Primaries nice and perfect!
Old Jan 20, 2012 | 06:35 AM
Zooomer's Avatar
Supporting Vendor
the pacesetter is crappy w/o being modified. the ball socket style flange is junk.
Old Jan 20, 2012 | 07:53 AM
He has owned one before, from his cavy, and knows the install, he already ordered a Pacesetter header. He plans to modify it to fit his ZZP downpipe he already has.
Old Jan 20, 2012 | 08:00 AM
Staged07SS's Avatar
Administrator
Administrator
I have a pacesetter on my Cavy (winter beater).
It's been on my car since 2004, and has never once given me a problem.
The only thing I hated about it was the make shift downpipe. Other than that, it has been great!
Old Jan 20, 2012 | 08:32 AM
Yup it is a great mid length header for its price tag
Old Jan 20, 2012 | 10:37 AM
Blowncavy's Avatar
Does someone actually sell an downpipe that will bolt up?
Old Jan 20, 2012 | 11:56 AM
IonNinja's Avatar
+1 on the ball joint setup, not a fan either.
I wouldn't hack up your ZZP downpipe man. That's just me though.
The only company I know of that makes a bolt in solution for the Pacesetter is Exhaust Depot
Old Jan 20, 2012 | 12:02 PM
nhanson's Avatar
I have 0 issues with my midlength combo.
Updated V band flange is nice and tight and sealed.
Old Jan 20, 2012 | 12:08 PM
1AJeremyD's Avatar
Glad to hear someone with it on their car finally chime in. I was thinking of either doing the ZZP dp and badmab combo that everyone does or the ZZP midlength. I really like the fit and finish on the ZZP product so I'm probably going to go with them in the end.
Old Jan 20, 2012 | 12:21 PM
ebristol's Avatar
OTTP makes one. And it is very well priced.
OTTP Pacesetter Down Pipe
Old Jan 20, 2012 | 12:36 PM
Blowncavy's Avatar
I just seen that, that will bolt up to my header right?
Old Jan 20, 2012 | 12:48 PM
badmab is good stuff, i have them, and my dyno sheet is actually the one on their website. i had pacesetter on my cavalier for 4 years and i loved it, never gave me any issues. I think maven had one on his 400hp balt if im not mistaken.
Old Jan 20, 2012 | 12:50 PM
ebristol's Avatar
Yes. With the hardware that is included in your pacesetter the box.
But as some people have stated, sometimes there is a problem with the seal between those ball flanges and sometimes they can leak. But not everyone has that problem.
The other thing to consider is the size of your cat-back. Is your ZZP DP designed to bolt up to a 2.5" or 3" cat-back? I am pretty sure the one from OTTP will only bolt up to a 2.5" cat-back.
Old Jan 20, 2012 | 12:53 PM
1AJeremyD's Avatar
ZZP lists theres as fitting a 2.5" Long tub is for the 3"
Blowncavy's Avatar
Yes, I have the stock catback and its 2.5.
Looks like ill be getting this downpipe. Thanks
Another thing, does it have any gaskets for this? Like the one where the header and downpipe meets?
Old Jan 20, 2012 | 07:14 PM
YelCal7's Avatar
Just stick with BAD MAB header with ZZP 3inches downpipe catted with 2.5 exit. But don't use BAD MAB or ZZP gaskets. They don't last that long. Get copper gasket for head to header and Remflex gasket from header to downpipe. If you're thinking it's 2.75 not 3inches gasket. Doesn't matter cause Remflex seals up the leak and you will never get any leak at all for a long time. Won't have to worry about it. Compare to Pacesetter n ZZP mid length header it will rust up from time to time. While BAD MAB and ZZP 3inches downpipes are stainless steel. Means that they will last you a very long time. It make your money worth it. They are dyno proven for many Cobalt owner who has it. It's your money you decide what you are paying for. Personally I would go with BAD MAB with ZZP 3inches catted downpipe with 2.5 exit stainless steel. That is what I would go for.
