Beating the heat with TVS?
Old Aug 31, 2009 | 12:32 PM
  #76
Deathscythe's Avatar
damn, talk about a shorty! It looks good though.
And house>car everytime. I'd rather have a house to live in with no ride, than have to live out of my car.
I can wait till next year, when things get warm again. The time will present itself.
Old Aug 31, 2009 | 12:40 PM
  #77
2K5SS/SC?'s Avatar
She sure is a pretty Miniram. Getting the wastegate off the o2 housing, welded the flapper hole shut in the turbo, and getting rid of my crazy boost creep is the key there. 234whp and 210wtrq at 12psi is fun, but 20-24psi is gonna be mo betta!
Sorry for invading you thread Rodimus.
Old Aug 31, 2009 | 01:16 PM
  #78
After the tvs, i don't wanna go back to stock. 12psi is boring. And I still want MOAR!!!
Yeah, rod, what he said.
Old Aug 31, 2009 | 02:08 PM
  #79
ebristol's Avatar
Ok. I know a way to clear this up. Let's answer a few questions. For starters, where exactly does the pickup for the iat2 reading come from. Namely where exactly between the maf and the head?
Very good point. The IAT2 readings come from the MAP sensor located at the top of the IM after the laminova cores.
If you wanted to get the lowest possible IAT2 readings I would suggest hooking up a Cry O2 kit and spray it directly on the MAP sensor. As everyone know that will not improve performance other then trick some of the ECU adders IAT2 tables to advance timing. (which is not good).
A true test of a cooling mods effectiveness is in the EGT temps. EGTs mean a lot more then IAT2s.
Old Aug 31, 2009 | 02:12 PM
  #80
twzted's Avatar
I have killer chiller on my car atm...(not hooked up atm)
I am only running 50% fans, no meth
this weekend meth/fans and KC will be all put back on...
right now I am averaging vabout 25* above ambient cruising
i will keep you all updated
PS 2k5, i seen your other half of the project not done yet, but i knows
Old Aug 31, 2009 | 02:20 PM
  #81
I am going to explore where the best site would be for meth injection, since I'm not totally convinced that injecting through the intake is the best method. It's more than likely the easiest. I already have one 7gph nozzle tapped into the neck of my supercharger (shhh, no one can see it...) and I'm thinking about using two more in the intake manifold, going downstream right before the laminovas. I have to look at my ported intake manifold again, to see where the best points of injection are going to be.
Besides, only cheaters fool the map sensor for good readings.
Old Aug 31, 2009 | 02:32 PM
  #82
ebristol's Avatar
Remove the fuel injectors from this IM spacer plate and insert Meth nozzles.
Best solution ever!
Old Aug 31, 2009 | 02:35 PM
  #83
Don't give me any ideas.
Old Aug 31, 2009 | 05:53 PM
  #84
2K5SS/SC?'s Avatar
twzted, shhhh.... you no speaky about my side projects please.
Old Aug 31, 2009 | 05:58 PM
  #85
withholding info, are we???
Old Aug 31, 2009 | 06:03 PM
  #86
2K5SS/SC?'s Avatar
Nope, not withholding information. Just using the Privacy Act for now for good reason. Well, I'm leaving for my mission now. See you guys in a few days.
Old Aug 31, 2009 | 06:06 PM
  #87
lata
Old Sep 1, 2009 | 12:37 AM
  #88
twzted's Avatar
I wouldn't tell, i got my own thing going on right now anyway...so urs doesn't even matter to me :P
<3
Old Sep 1, 2009 | 02:53 AM
  #89
Omnigear's Avatar
Best solution ever!
4 nozzles? where is the diy for that?
question if you have it before and after , wont there be a delay for you to get
the whole spray of meth? if so how do you tune for that?
the radiant heat from the road does not help cool anything since my H/E is right on the ground, well its close. i prolly need to get a bigger rig than what i have , im using a H/E from a lightning.
Old Sep 1, 2009 | 04:19 AM
  #90
HunterKiller89's Avatar
the stock cobra one be tiny dude.... man up and buy a real HE
Old Sep 1, 2009 | 04:35 AM
  #91
Steven Flit's Avatar
cobra h/e > all
Old Sep 1, 2009 | 09:29 AM
  #92
ShortStack's Avatar
Originally Posted by Steven Flit
cobra h/e > all
no.. no its not...
Old Sep 1, 2009 | 10:16 AM
  #93
ebristol's Avatar
That is just an idea I had. No one has ever done it. I am the only one who has this IM spacer. I guess someone could tap the IM in 4 different places and spray that way.
I have had this IM space plate for about a year now and don't know what to do with it. Right now there are 4 Siemens 60# injectors in there. But those ports could be threaded and meth nozzles could be added pretty simple.
question if you have it before and after , wont there be a delay for you to get the whole spray of meth? if so how do you tune for that?.
If you spray before there is already that delay. But it is so minimal I would not be concerned about it.
Old Sep 1, 2009 | 11:21 AM
  #94
2K5SS/SC?'s Avatar
I think 4 jets would be a little too much though. I'd like to see it done though for testing purposes.
Old Sep 1, 2009 | 11:44 AM
  #95
freakta's Avatar
You should not make those claims unless you are able to back it up with UNBIAS proof.
you must beout of the loop. there are a few people on herewith air to air setups. ive posted results of mine and have shown huge drops in temps....
and also i have 4 meth injectors and it works very well also
Old Sep 1, 2009 | 11:45 AM
  #96
I'm thinking about using three for mine. One in the neck of the supercharger, and two in the intake manifold.
Old Sep 1, 2009 | 11:47 AM
  #97
Originally Posted by ShortStack
no.. no its not...
he knows. he's just jealous because i have a real HE and he has a cobra....lol
  #98
ShortStack's Avatar
Lol.
Old Sep 1, 2009 | 12:15 PM
  #99
STS2/SS's Avatar
DO NOT GET METH ON THE TEPHLON ON THE ROTORS!!!!!!!!!!!!!!!!!!!!!!
It will disinigrate it very quickly and you will notice over time a slight decrease in performance!!!!!
The injectors must be external mount from D.O. and they need to spray into the runners on the (HEAD) If you want mega gains like freakta or myself you will do it like this otherwise your just hurting performance and thats like throwing money away!
I am working on using servo controllers to spray with fuel! That will give you the most controlled gains I have heard of over 70hp on other projects they didn't have dyno's posted?
I know for a fact with the cobalt community and grandprix community freakta and myself are making the most HP with METH we kinda know what where doing.
Old Sep 1, 2009 | 12:36 PM
  #100
freakta's Avatar
Originally Posted by hungryhip-ccp
What a waste of money, shoulda went turbo... now your fucked sell that paper weight and buy a turbo if you want power, if not go back to stock... should of done some research first and you would of found the tvs is not a smart choice...
please dont waste space with posts like this, you are no help
