best H/e
Old Jun 19, 2010 | 01:30 PM
timhebert's Avatar
best H/e
whats the best heat exchanger on the market that bolts right up?
Old Jun 19, 2010 | 01:31 PM
scotch89's Avatar
S3 zzp
Old Jun 19, 2010 | 02:01 PM
timhebert's Avatar
is that better than ottp
Old Jun 19, 2010 | 02:09 PM
scotch89's Avatar
i really dont now but from what i heard yes. im satisfied
Old Jun 19, 2010 | 02:11 PM
Pyros777's Avatar
I own the OTTP H/E. It gets the job done and is built like a tank, so it can withstand some accidental/unexpected scraping.
The ZZP S3 unit is better by design and will keep your temps cooler, but because of its lighter construction it is more susceptible to being bent/broken by accidental scraping.
They both have their pros and cons but ultimately neither can match a Griffin h/e. The Griffin unit replaces the stocker but is twice the depth so it provides superior cooling with a single unit instead of having to run two h/e in series. It costs ~$700 though. Similar in price to a Hahn I/C for the T/C.
Old Jun 19, 2010 | 02:14 PM
Brenticus's Avatar
That's what I've heard too. Zzp more brittle but better at cooling. OTTP is tough with slightly less cooling. I'll be getting OTTP because of where I live.
Old Jun 19, 2010 | 02:16 PM
timhebert's Avatar
damn yea thats to much for a h/e, how much better is the zzp
Old Jun 19, 2010 | 02:20 PM
Pyros777's Avatar
Maybe worth a few degrees F. Not really sure.
Old Jun 19, 2010 | 02:21 PM
timhebert's Avatar
ill prolly go with the ottp since its like 30 cheaper, and stronger. it should go good with the meth. thanks for the input guys
Old Jun 19, 2010 | 02:22 PM
scotch89's Avatar
ya its hard to say with out having both of them and kinda doing some datalogging if that makes sense
Old Jun 19, 2010 | 02:40 PM
roderick's Avatar
LFP Dual pass heat exchanger. droped my temps by 25 and has worked great. I got it for 120. it is bigger then zzps.
Old Jun 19, 2010 | 07:37 PM
Erick161's Avatar
Cobra H/E?
Basically you need to find which one works better for you and your needs. Here, with so much heat in my area, i'll be using the S3 H/E
Old Jun 19, 2010 | 07:40 PM
rossshady120's Avatar
i got the CA H.E i was told its the smallest on the market
Old Jun 19, 2010 | 10:16 PM
timhebert's Avatar
where'd u find the lpf. and why is it so cheap if its bigger
Old Jun 19, 2010 | 10:47 PM
troyss's Avatar
Cx racing I got. Seems to work
Old Jun 19, 2010 | 10:55 PM
EcoTecDriver's Avatar
I heard the cobra HE is not much better then stock? truth?
LFP Dual pass heat exchanger<----whats the build quality like? and it runs with the stock unit right?
Old Jun 19, 2010 | 10:58 PM
1badBlueberrySC's Avatar
I swear... I still have yet to see anyone keep cooler temps then my LSJ with a 2.7 meth, and a COBRA H/E!
After 4 back to back drag runs I kept a pretty consistant 110* IAT2.... The cobra does just fine!
Old Jun 19, 2010 | 11:38 PM
roderick's Avatar
LFP is Lightning force performance. They make a redline and cobalt h/e now. The one I got was for a mustang but its huge and does wonders. I got it brand new from a guy on redline forums for that price.
http://dagostinoracing.com/index.php...ducts_id=11828
Thanks the one I got I believe but if you call them you can get one cheaper for your car.
Also when I got mine zzp didnt have any h/e for sale everyone was just getting a small cobra h/e
Old Jun 20, 2010 | 12:16 AM
insylem's Avatar
Does haveing HE effect the operation of your AC? Does it raise your COolant temps since its warming up the air before it hits your regualr radiator?
Does pumping all the extra fluid wear out your IC pump faster?
Old Jun 20, 2010 | 02:55 AM
Pyros777's Avatar
The air damn below the factory h/e and radiator pull air from under the car up towards the radiator, so factory temperatures are not affected at all.
edit: that LFP looks pretty good!
Old Jun 20, 2010 | 11:21 AM
Matt M's Avatar
ZZP also has the S2 unit if you are looking to save some money.
https://www.zzperformance.com/cobalt...1054&catid=178
Old Jun 20, 2010 | 11:43 AM
05Slowline's Avatar
ZZP is brittle? Really? I distinctly recall seeing a post of the zzp h/e after the car was involved in a front end crash and it was dented back but didn't leak a drop. Don't take less weight for more brittle. They make their s3 in house IN AMERICA and it's top notch /thread.
it's not stronger and it's cheaper for a reason it's from ******* china people posting in this thread don't know wtf they're talking about.
zzp s3 is far superior in every way.
- no drain plug at the bottom that will catch on things and cause leaks
- better cooling
- better internal design
- weighs less than 10lbs
i could go on
Last edited by 05Slowline; Jun 20, 2010 at 11:45 AM. Reason: Automerged Doublepost
Old Jun 20, 2010 | 12:18 PM
Omnigear's Avatar
zzp stg3 its the truth cuz ottp didnt even rebuttal on zzps claim.
^_^
Old Jun 23, 2010 | 05:56 PM
timhebert's Avatar
after reading on zzps website that the s3 is only slightly better i decided to go with the ottp h/e
Old Jun 23, 2010 | 06:10 PM
Omega_5's Avatar
If you want to talk 'best'... the Griffin HE from the GA cars is the best... but you will pay for it. And the only way to get it is to call up Griffin and beg to them to build you one.
As far as add-on front mounts go, the ZZP Stage 3 is the best you can get. It uses a real deal water to air core, with light weight end tanks. It is far more efficient at displacing heat from the coolant.
Next in line, you'd have the ZZP Stage 2 / OTTP system, which is pretty much a decent budget core made in China. It's basically a modified air to air core with channel stock end tanks. A fair bit heavier, and less efficient... but gets the job done.
Next is the ZZP Stage 1 / CXRacing / etc systems. They are a real budget core, with a real budget design. Usually a smaller, air to air core with channel stock end tanks. Even less efficient than the other deigns.
