Bleeding the clutch?? Need help bad
Old May 23, 2012 | 08:46 PM
rouseySS/SC's Avatar
I installed my clutch and new throw out bearing and have been trying to bleed the system for about 5 hours and I can't seem to get the pedal pressurized. I used the method from the lsj gm hand book in chapter 5 and just haven't seen gotten any pressure. Can anyone point me in the right direction?
Old May 23, 2012 | 09:00 PM
brideout_8's Avatar
I just changed my clutch whenever I did my turbo swap. I had a friend open the bleeder as I pushed the clutch in. Once I hit the floor he closed it and I pumped the clutch few times. Then we repeated several times. That seemed to work for me.
Old May 23, 2012 | 09:41 PM
Did you use the master cylinder up to or the bleeder valve in the tranny
Old May 24, 2012 | 07:15 PM
Well I figured out why I couldn't build pressure, the hydraulic fitting on the throwout bearing was not on square and was leaking making it not get pressure so tranny is off and problem appears to be fixed
Old May 24, 2012 | 11:44 PM
Bluelightning's Avatar
Got Bewst?
When I did mine I just cracked the bleeder and let it gravity feed for around 15 minuites. After a few bleeding sessions it was done. I have seen people make a cap for the brake resivoir and regulate an air blower to 10psi. Then pressurize the resivoir to force the fluid through the system.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
