Blet tensioner help
Old Feb 6, 2010 | 02:19 PM
HAZ's Avatar
HAZ
Blet tensioner help
I am trying to loosen the tension of the belt but it won't move at all. I have read guides here for some instruction but nothing works. Clockwise, counterclockwise, pushing down, none of it makes the tensioner pulley move. Is there any way to release some tension besides taking a wrench to it like everyone says?
Old Feb 6, 2010 | 02:26 PM
rnjmur's Avatar
I have an 18 inch prybar that I use on it.
Fonzi1289's Avatar
Taking off the blower.
Old Feb 6, 2010 | 04:15 PM
terry11's Avatar
15 mm wrench and push towards the firewall. Not that hard man. If you strip the top part off it like i did from taking it off and on so much a pry bar and the right angle and everything is just as easy.
Old Feb 6, 2010 | 04:58 PM
YzRider452's Avatar
Our tensioners are a pain in the ass. Figured they would design a better way for us to do it. My **** stripped the first time i used it. Pry bar FTW. i guess...
Old Feb 6, 2010 | 05:09 PM
HAZ's Avatar
HAZ
Loosening the blower worked. Now I can finally finish this stage 3 install. thanks guys.
Old Feb 6, 2010 | 05:12 PM
Fonzi1289's Avatar
HAHA ur welcome.. i did it that way.. figured it was much faster than spending the time trying to find the right and with a pry bar or wrench
Old Feb 6, 2010 | 05:32 PM
rnjmur's Avatar
You really should remove the belt BEFORE removing the blower. If you damage the gasket, then you have to replace it. Also, why risk damaging the intake manifold when you can run down to the store and buy a prybar and take the belt off in 2 seconds?
DarrenGC
Dec 24, 2021 01:55 PM
SmitBag
Sep 7, 2016 08:05 AM
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
bobbob160
Sep 15, 2015 11:31 PM
