Blower rotor bearings
Old 04-23-2007, 09:39 AM
eastcoastz's Avatar
My friends rotor bearings are grinding in his Ion so Im going to relace them for him and I just hve a few questions. Any special tools to remove them? Are the bears the same for our Gen 5 M62 as the Gen 4? Thanks
Old 04-23-2007, 08:19 PM
blueta's Avatar
Are you sure it's the bearings and not the coupler? Seems like a common problem with eaton's junky stock one. It's a really easy and cheap fix if that's the problem. To check for it take off the belt and turn the pulley back and forth. If there is any play before it catches it's the coupler. I never changed the bearings so no help there.
Old 04-23-2007, 09:44 PM
CobaltSS313's Avatar
yah ive noticed the same problem with my blower, at first i thought it was the rotors grinding but when i listened closely it sounds like a bad bearing.
Old 04-23-2007, 09:48 PM
Smarty Art's Avatar
We took a blower apart that has had a 2.5 on it for a long time. The bearings in the snout where perfect. Nothing wrong with them. We think the needle bearings bit the dust. The rotors expanded a bit and ripped into the housing. The coupler goes bad you usually hear a rattling sound from the charger. ZZP makes a stronger coupler then the stock one.
Old 04-23-2007, 10:16 PM
eastcoastz's Avatar
I changed the coupler months ago with the ZZ one. I know its the needle bearings for sure I just need to know if the bearings are the same for Gens 4 and 5? If so do I need any special to to remove or install them. I want to order everything at the same time.
Old 04-23-2007, 10:17 PM
Smarty Art's Avatar
Don't know if you can remove them. They might be pressed in. We got a brand new charger so I can't help you on that.
Old 04-23-2007, 11:03 PM
Shortbus's Avatar
ADD GREASE, if the bearings all are straight, and not crooked or out of a straight line, just re-pack them with grease.
Old 04-23-2007, 11:07 PM
eastcoastz's Avatar
Ok thanks! Any special way to repack them?
Old 04-24-2007, 07:34 AM
blueta's Avatar
If you don't have a grease packer you can take a wad of grease in your palm and hold the bearing in the other. Keep hitting the open sides of the bearings into the grease. Repeat until you think it's in there pretty good. That's the ghetto way of packing grease without a packer, but it works. Oh yeah, wear some rubber gloves
01-12-2016 12:01 AM
jimbofug007
10-02-2015 12:06 PM
DANRICKARD
10-01-2015 12:08 AM
goaliemo
09-28-2015 01:37 PM
grampss
09-27-2015 08:51 PM
Quick Reply: Blower rotor bearings
