Blown Engine??
Old Sep 29, 2008 | 03:55 PM
  #51
EatonTVS07's Avatar
leak down test i stil think those numbers are to high for it to be blowm
Old Sep 29, 2008 | 07:58 PM
  #52
MLeclair's Avatar
Leak down test? What is that...lol
Old Sep 29, 2008 | 08:31 PM
  #53
EatonTVS07's Avatar
well i dont even think you'll need to do one i mean if it was a fried ring or landing compression wouldn't be 160. hell last time i checked on all data spec was lower then that. try to find a temp gun and point it at each exhaust port, see if 3 is substantially cooler then the others
Old Sep 29, 2008 | 08:50 PM
  #54
MLeclair's Avatar
Alright i'll give that a shot. I'll see if my friends have any.
Old Sep 29, 2008 | 09:02 PM
  #55
EatonTVS07's Avatar
cool cause when i got my car something similar happened, thought i blew it so i took it into my teachers shop did a compression test and came out with similar results did the temp gun and the temps were pretty close i believe within a couple hundred degrees at most, so i ruled that out. the blower sounded weird like it was leaking air and the car sounded like a subi, but after looking into it more, the cat was clogged it fouled out my o2 sensor and it created so much back pressure it blew my by pass valve open, and that was that. but when it was clogged it struggled to get to 5600 rpm and would only boost to 10psi after that it sounded like it was leaking real bad
Old Sep 30, 2008 | 02:03 AM
  #56
MLeclair's Avatar
Hmmm I dont have a cat.. i have the catless ZZP downpipe. I talked to my GM friend, and he said buy new pistons.. 180/180/160/180 is not to bad... but maybe that 3rd one is damaged? It struggles big time getting passed 5600RPM too.. but i haven't really tried hah..
Old Sep 30, 2008 | 02:58 AM
  #57
tREBs's Avatar
mike! were u driving your car at dixons pub today?!
i couldda swore i saw u driving away
Old Sep 30, 2008 | 10:29 AM
  #58
EatonTVS07's Avatar
By pass valve maybe whats the most boost the car will push
Old Sep 30, 2008 | 07:25 PM
  #59
MLeclair's Avatar
I'll check scared too tho..
Old Oct 1, 2008 | 01:56 AM
  #60
MLeclair's Avatar
Quick test... 15 PSI at 4000RPM and 16 PSI at 5000RPM. then i stopped.
Old Oct 5, 2008 | 04:28 AM
  #61
MLeclair's Avatar
The car before she blew!! Taking it apart tomorrow!
Old Oct 5, 2008 | 05:22 AM
  #62
steddy2112's Avatar
Originally Posted by 0redline6
that wouldnt make the cel light flash.... if the cel flashes... its bad... real bad lol... trust me just happened to me im in the porcess of waiting for **** and getting my car backtogether
Originally Posted by NGalaxyTimmyo
haha, I've had the blinking cel
It's the cars way of saying "WHAT the HELL do you think your doing!!"
Flashing CEL always means some sort of misfire.
Whether multiple or not, you will have to scan.
Old Oct 5, 2008 | 06:16 PM
  #63
EatonTVS07's Avatar
so its actually blown huh. damn shame car looks awesome
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ThoR294
Sep 28, 2015 05:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
