Blown piston rings??
hey guys i took a video of my car with its oil cap removed and its not pretty.....if i take my plugs out they are covered in oil. im guessing blown rings idk u tell me. if you could tell me how much it would cost to fix it that would help. im pretty good mechanically wise but iv never torn our engines apart internally before. thanks
Blown piston rings...? - YouTube
Rings aren't hard you don't even have to pull the engine. Pull the head and drop the oil pan. Unbolt rods and push them up. Might have to install new rings and file them to appropriate size and reinstall everything. Might have to hone the cylinders but might not.
you need to have the bore checked to make sure it is still round and that there is very little to no taper in the bore if the cylinder is out of round and has to much taper you will burn oil and the piston bouncing around in the bore will eventualy bust a sleeve or bust the skirt off the piston
