Boost!!!
Old Jul 24, 2006 | 07:36 AM
06cobaltss/sc's Avatar
Boost!!!
how much boost can the stock lsj motor take.
Old Jul 24, 2006 | 07:46 AM
Acidangel_5.0's Avatar
11 x billion
Old Jul 24, 2006 | 07:50 AM
thats amazing
Old Jul 24, 2006 | 08:06 AM
R33P3R007's Avatar
360 L337 User
isn't it 11.5 billion search buttons worth.
Old Jul 24, 2006 | 08:15 AM
Serpico's Avatar
eleventybillion
Old Jul 24, 2006 | 08:16 AM
Serpico's Avatar
Old Jul 24, 2006 | 08:19 AM
1stbluSS's Avatar
answer the guy already. I would highly recommend nothing over 18 lbs without upgrading heat exchanger, aftercooler or something of the sort to keep the temps down.
Old Jul 24, 2006 | 08:30 AM
WSFrazier's Avatar
I am currently at 21 psi
Old Jul 24, 2006 | 08:39 AM
i was thinking about getting the intense stage 5 but i wasnt sure if the boost was safe for stock internals. i think its safe because if you are running 21 psi and nothing has blown up yet... ecotec is a strong engine from factory. i m thinking about getting a better head gasket though. and i just got a port and polished head.
Old Jul 24, 2006 | 09:07 AM
BLKSS's Avatar
Whatever the blower can take. Id say 20psi would reasonable.
Old Jul 24, 2006 | 09:09 AM
WSFrazier's Avatar
I think we agreed that with a 2.7 pulley and the engine at 7K your just making it below the blowers redline. So anything lower than that, you will be going beyond the blowers redline. Although that is only if you take the car to 7K. I am sure no one drives the car to 7K on every shift. Least I hope not.
Old Jul 24, 2006 | 09:15 AM
i hope no one hits 7k all the time. there would probably be some damage to the super charger
Old Jul 24, 2006 | 09:24 AM
06blackg85ss's Avatar
**** I"m running a 2.6 at 7400 rpm's, thougj I rarely run it up that high... hasn't blown up on me yet... by the way does anyone know if someone makes a high speed bearing conversion for the m62, like 18-20k kit...
Old Jul 24, 2006 | 09:27 AM
WSFrazier's Avatar
Yeah I got my RL set to 7400 as well, although even if I am running it hard, I usually just shift at 7K. I pretty much did that just to make sure I would never bounce off the limiter. Or if I am at the track and want a better trap in 3rd.
Eaton says its ok to go over the RL of the blower once in awhile. Just do not run that small pulley on a road course where your constantly in that high rpm range. Least I think it was eaton that said that.
Old Jul 24, 2006 | 09:35 AM
wow... i hope you dont have a problem when you rev that high cuz i would hate to see the supercharger let go. i havent heard anything about a higher rev bearing kit though. with a 2.5" pulley i wouldnt take it over 7k.
Old Jul 24, 2006 | 09:44 AM
WSFrazier's Avatar
So far I haven't either, lol. Nor do I really want too.
Old Jul 24, 2006 | 10:51 AM
thats good. it would suck to blow up a supercharger
Old Jul 24, 2006 | 10:55 AM
djt81185's Avatar
37.25948349450459204590245 psi
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
