Boost at idle
Old Sep 21, 2007 | 08:06 PM
quickspec's Avatar
Boost at idle
What is you alls boost gauge reading at idle?
Old Sep 21, 2007 | 08:35 PM
redrocket's Avatar
Should be about 18" of vacuum, steady.
Old Sep 21, 2007 | 08:37 PM
NJHK's Avatar
You shouldn't have any boost pressure at idle. Your bypass valve would be open at that point.
Old Sep 21, 2007 | 08:38 PM
Gamebay11's Avatar
At 600 feet above sea level, I see about 20 - 21" vac.
Old Sep 21, 2007 | 09:18 PM
fballman1987's Avatar
mine sits at like-18 at idle
Old Sep 21, 2007 | 11:40 PM
Onyxd04Redline's Avatar
X2
Old Sep 21, 2007 | 11:53 PM
FryLoch's Avatar
around 18 vacuum
Old Sep 22, 2007 | 09:52 AM
quickspec's Avatar
I ask, because on my interceptor gauge it reads -8psi, is that normal?
Old Sep 22, 2007 | 11:00 AM
InfinityzeN's Avatar
About 20" of vacuum for me.
And it reads -8psi because it is trying to read vacuum. Don't know if the Interceptor has the ability to display vacuum or not.
Old Sep 22, 2007 | 02:10 PM
LopsidedJester's Avatar
same here, i'm at about -9psi on the interceptor and when i downshift it jumps to -11psi, but no higher really.
Old Sep 22, 2007 | 02:33 PM
RaineMan's Avatar
right around 20 in vac.
Old Sep 22, 2007 | 02:34 PM
TVS_SS's Avatar
-60 kpa
Old Sep 22, 2007 | 04:43 PM
quickspec's Avatar
So it's normal then to see 8psi at idle on a interceptor?
Old Sep 22, 2007 | 06:40 PM
NJHK's Avatar
Where did you get 8 from?
Old Sep 22, 2007 | 08:14 PM
quickspec's Avatar
Oops. i mean -8.
Old Sep 23, 2007 | 05:39 AM
HunterKiller89's Avatar
yes^^
Old Sep 23, 2007 | 10:16 AM
Isn't the ratio for the conversion 2.4XXX something or other. As in -8psi would be around 19 or 20" of vac. Damn it, can't remember and I'm too lazy to search for it.
Old Sep 23, 2007 | 08:12 PM
Johnboy12358's Avatar
My interceptor shows between -20 and -22 when I am engine braking, about -18 to -20 when I am stopped, dead idle.
Old Sep 23, 2007 | 08:23 PM
What measurements are you going with, percentages? i did port and polish my supercharger housing, i dunno if that would effect mine at all. I still see about 15psi max with my mods. Vaccuum is about 14.7 psi so i guess seeing around -9 psi to -11 psi would be normal, because it wouldn't be FULL vacuum, just close. also -9 psi = -62 kpa
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
