Boost Juice or Different Solution for Water/Meth?
Old Apr 9, 2007 | 07:22 PM
DTM2188's Avatar
For those running a water/meth kit, what solution are you using? I heard about Boost Juice, regular window washer fluid, and other solutions. But which is most beneficial and where are you buying it from? Thanks in advance.
Old Apr 9, 2007 | 07:31 PM
Psykostevo's Avatar
Don't use Regular windshield washer fluid. It has to be certain types.
The best is Wal Mart's SuperTech Wintermix Formula (has to be Winter Formula) Already a perfect Water Meth mix, and it's about 2 gallons for $1.00 :-) Happy spraying!
Old Apr 9, 2007 | 07:35 PM
DTM2188's Avatar
Thanks man! Do you know what the % of meth is in that? I know the Boost Juice is 50/50 and most window washer fluids are 20/80 I think.
Old Apr 9, 2007 | 07:51 PM
zinner's Avatar
Moderator Alumni
Also make sure there is no anti freeze in the washer fluid.
Area47's Avatar
Rent me! per hour
winter mix has more methanol in it to prevent freezing.
ANY blue colored winshield washer fluid WILL work.
the closer you get to the 49/51 percent mix rate {ie winter mix} the better, but summer mix will work fine.
Old Apr 9, 2007 | 08:03 PM
DTM2188's Avatar
I just read that the winter mix is anywhere from 33-38% meth, while the boost juice is 49%. Will there be a significant performance difference between the two? I mean your comparing $2 to $11.
Old Apr 9, 2007 | 08:14 PM
Rodimus_Prime's Avatar
I use the snow performance boost juice, you never know whats in that wiper fluid stuff and at its rarely as closely 50/50 as the snow performance stuff
Old Apr 9, 2007 | 08:16 PM
DTM2188's Avatar
^^^Thats what I was thinking about getting. $44.90 shipped for 4 gallons is a lot though, but I think thats the route I'm gonna go anyways.
Old Apr 9, 2007 | 09:07 PM
Area47's Avatar
Rent me! per hour
if you're just using it for cooling properties, windshield washer fluid is fine.
water does NOT add hp.
you can spend 45 bucks a month, or 8 bucks a month. up to you. im just offering my personal experience with water injection.
Old Apr 9, 2007 | 09:22 PM
mezzanno's Avatar
im using washer fluid. -25 F.
Old Apr 10, 2007 | 12:02 AM
Ljavy17's Avatar
im using the blue -20 stuff, I am able to run 21 degrees of timing with that, However I would probably need the 50 50 for the 25 degree of timing. So yeah there is a performacne gain in it.
Old Apr 10, 2007 | 02:15 AM
JMAc88's Avatar
Just find a tuning shop most carry meth, i get a huge gerry can for around $20, pick up some distilled water at a store, then i mix mine %70 meth 30%water. A large Gerry can will last me 2-3 months depending on how often i goto the track
Old Apr 10, 2007 | 06:16 AM
DTM2188's Avatar
Thanks for all the input!
Old Apr 10, 2007 | 12:23 PM
06noscobaltss's Avatar
I use boost juice in mine for now but as soon as I go through all 4 gallons Ill be mixing my own. I work for Jiffy lube and we get straight 100% methanol in 55 gallon drums cause we mix it outselves for our windshield washer solvent. so Im set for as long as I work there!
Old Apr 10, 2007 | 12:41 PM
burntorange's Avatar
Can you guys post some links to/about this meth injection...thanks guys, just would like to learn more about where are some good places and prices to buy it for. (including the entire kits.)
Old Apr 10, 2007 | 12:47 PM
07cobaltowner's Avatar
here is a link i found
http://www.dieselsite.com/index.asp?...S&Category=300
http://www.alcohol-injection.com/
Old Apr 10, 2007 | 06:05 PM
DTM2188's Avatar
Also try www.snowperformance.net. Some of our vendors sell the kits as well (CA, TAG, etc). For anyone interested I am trying to get a a group buy going for the Boost Juice through SnowPerformance. I'll keep everyone updated, but let me know if your interested before I start a seperate thread on it.
Old Apr 10, 2007 | 07:11 PM
yellowcobaltss05's Avatar
im gonna use the boost juice only bc snow performance warranties there kit if you use only Boost Juice.
Old Apr 10, 2007 | 07:15 PM
jeremie's Avatar
i use boost juice as well. washer fluid usually doesnt say what they use in their solution, or the percentage of ingrediants. and yes, snow perforamnce will warranty their products if you use boost juice. i know some guys who dynoed a diesel truck and used washer fluid and boost juice, and the boost juice actually put down better numbers.
Old Apr 10, 2007 | 07:17 PM
DTM2188's Avatar
Good to hear that everyone seems to like Boost Juice, which I have decided will be the way I go. Now I'm just trying to get a group buy going on it thru Snow, we'll see how it goes and keep everyone updated (especially if people are interested).
Old Apr 10, 2007 | 07:21 PM
intense_SS's Avatar
i would be interested in the boost juice when i get my kit!! should be here in like a week but i got the devils own!! did you guys see the nitro stuff on the snow performance website? its right under the boost juice but what is it for?
Old Apr 10, 2007 | 07:25 PM
DTM2188's Avatar
^^^I'll have to check it out and I'll keep you posted if I can get a GB going on the Boost Juice.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
nathan112i
Sep 30, 2015 07:12 PM
metroplex
Sep 27, 2015 07:48 AM
