Boost question
Old May 20, 2012 | 11:31 AM
paddock's Avatar
Boost question
I'm running GMS3 with a 2.8 pulley and ZZP header/DP combo.
I'm only hittin about 15.5lbs boost at WOT. Is that about right? Or should it be higher?
The last time I had the charger off, I kinked the gasket. I don't hear and leaks. Am I missing something??
Thanks.
Old May 20, 2012 | 11:40 AM
startingline05's Avatar
Spray some break cleaner around there while it's at idle. You will know if you have a leak or not.
Old May 21, 2012 | 05:00 PM
bren774's Avatar
im from ontario on stock setup with smaller tires and K&n air filter, i run anywhere from 13-15psi depending on the air temperature/pressure. I've seen 16psi hittin 150mph on a cold winter night
Old May 21, 2012 | 07:46 PM
willdrew's Avatar
are u on a custom gm stage 3 tune?
Old May 21, 2012 | 08:05 PM
carstedt's Avatar
15ish seems bout right
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
