Brutal sound from SC (Not Coupler..)
Old Dec 4, 2010 | 08:43 PM
CanadianCobalt's Avatar
Unhappy Brutal sound from SC (Not Coupler..)
I put on my Stage 3 Kit a little while ago and after I got my SC back from the dealer it was making what was said to be the "Bad Coupler" sound. The way everyone described it made sense but after replacing it the sound is still there, and I think getting worse..
It's turning to a grindy marbly sound that I'm afraid might be coming from the bearings on either end of the rotors. How would I go about checking these or replacing them? I took it to the dealer so they could use the proper tool to pull it and they said the tool it called for didnt work so instead they used a 3 jaw transmission puller (somewhere along those lines). And said they used a similair tool for install of the hub.
I'm at a loss on what to do, I've tried 2 different brand new couplers and replaced the oil.
Hopefully I don't need a new SC. Boosts and runs fine otherwise.
Joel
Old Dec 4, 2010 | 09:23 PM
SunburstSS's Avatar
Dang...Most Likely the bearings, mine were done i rebuilt my supercharger like a month ago...
https://www.cobaltss.net/forums/2-0l...harger-232469/
I still have my old bearings i put it on my finger and spinned it, and the sound was like marbles haha and yes they were broken ....
Old Dec 4, 2010 | 09:58 PM
Thats uber shitty.
I have access to a press, where did you get your bearings from? Any diagrams on how to do it?
I looked in your thread and it didn't make much sense without having it to look at haha.
Joel
Old Dec 5, 2010 | 02:34 AM
Bluelightning's Avatar
Got Bewst?
Sounds like you're dealer did something wrong. Honeslty, you could probably find a used M62 cheaper complete, used then rebuild it. Plus you're already replaced a couple couplers. Just easier IMO.
Old Dec 5, 2010 | 09:15 AM
mrbelvedere's Avatar
you can find rebuld kits prettty resonable if you look but minr was and still is making the same sound and its the valve train
Old Dec 5, 2010 | 11:54 AM
I completely agree with the dealer screwing it.
They didn't use the proper tool and it got shady from there.
Never going back. I talked to them and it turns out they don't know anything about superchargers (I was informed differently before they had it). Shitty deal.
I guess I'll start looking for another M62, maybe I should just bite the bullet and go TVS haha.
Mine is for sure the supercharger. Stethescope on it, what was wrong with your valve train.
Joel
Old Dec 5, 2010 | 11:49 PM
So i tore her down today.
Oil was good and full. Rotos appeared to be scratching the rotor housing very slightly which could cause the grinding noise which would be from the rear needle bearings going. The other bearings feel fine. When the snout bearings go do they feel notchty at all? Mine are still smooth and I don't want to replace them if it won't help. Coupler is still perfect.
Joel
Old Dec 6, 2010 | 02:13 PM
send it to zzp they rebuild them
Old Dec 6, 2010 | 06:08 PM
For how much I'd pay in shipping I might as well by a used one if I went that route. Damn it living it Canada.
I'm getting a local bearing place to check out the bearings and such.
Joel
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
