Build Book Injectors?
Old Aug 22, 2006 | 12:22 AM
automobiliben's Avatar
I did a search and found nothing. Does anyone know what size the injectors are on the motor used in the build book, it says 5.64 gal/sec, but how many lbs./hr. is that? I found the density of gas to be 6.09 lb/gal, but if you do the conversion, something doesn't add up....or maybe being out of college for 3 months has hampered my math skills. Anyways, if anyone know I would greatly appreciate some help. Thanks
Old Aug 22, 2006 | 12:24 AM
vandy0419's Avatar
Dude...the build book is a 2.2L build...
HackAbuse's Avatar
5.64 gallons a second?!
Those must be some injectors!!!
Old Aug 22, 2006 | 12:26 AM
Blown 4-banger's Avatar
I did the math and it comes out to about ~34lbs/hr which is stock injectors
05BlackCobaltSS's Avatar
Wow, that's a LOT of fuel...I wonder how far one tank will get you....
Old Aug 22, 2006 | 12:27 AM
HackAbuse's Avatar
13 gallons / 5.64 = about 2.5 seconds!
Depends on how fast you're going i guess
vandy0419's Avatar
Stock on the LSJ...not L61...
He has a 2.0L and is looking for his own stock injectors, lol.
If you want injectors, hit up www.lightningforceperformance.com. They sell the 42# and harness for $179 and 60#s and harness for $220.
Old Aug 22, 2006 | 12:29 AM
vandy0419's Avatar
1 gallon doesn't equal 1 pound.
Old Aug 22, 2006 | 12:30 AM
I am not asking where to buy them. I wanted to know what size they are. And soorryyy, I was talking about the build book for the LSJ.
Old Aug 22, 2006 | 12:31 AM
How did you get that? They are running a 77.9 mm pulley and an 8k RPM redline, also is says right in the book that they upgraded from the stock injectors to these.
Old Aug 22, 2006 | 12:34 AM
Witt's Avatar
I know exactly what you're asking and am curious myself. On GMPD's 300hp LSJ build, they include the forged 10:1 pistons, Bates valve springs, neutral balance shafts, and a 2.85" pulley. They also included upgrading injectors and engine management and am also curious to what size they upgraded to.
Old Aug 22, 2006 | 12:35 AM
HackAbuse's Avatar
"book, it says 5.64 gal/sec, but how"
Its called a joke
vandy0419's Avatar
Expect to see a floating valve soon if your rev limiter is 8000rpm. GM recommends it not to go over 7250rpm on stock valves.
The build book for the LSJ is actually for the Time Attack one. That is actually just a Stage 2 tuned like a mother though with a NX kit. That put out 280whp I think w/o Nitrous. The 42.5s will reach over 100% duty cycle though with lots of tuning and a 2.7"
Old Aug 22, 2006 | 12:39 AM
Maybe its 42# injectors, 77.9 mm = ~3.1 inch
Old Aug 22, 2006 | 12:42 AM
Yeah, I realize about the top end and stuff, it is being covered. That is what I wondering about, from all that I have read a good DC to have is around 80% but have been reading about all of these people running 2.7 and 42.5 and running somewhere around a 120% DC, that just doesn't sound safe to me. But from my understanding an inject DC of over 100% sounded impossible, I think I need to do some more reasearch!
Old Aug 22, 2006 | 12:45 AM
vandy0419's Avatar
Lots of people seem to run over the 100% duty cycle. The Stage 1 for INTENSE the guy was running at 103% DC. There is no chance of ever running over 100% duty cycle with the 60s though because it is just flat out impossible with how the chart is set up in the PCM...unfortunately.
Old Aug 22, 2006 | 12:48 AM
We'll see about that soon enough...
Old Aug 22, 2006 | 12:50 AM
Witt's Avatar
They're running a 73mm pulley which is 2.87 inches in the 300hp LSJ book.
Old Aug 22, 2006 | 07:31 AM
vandy0419's Avatar
How can we see about that? You have HP Tuners...you know for a fact that the chart cuts off at 63lb
Old Aug 22, 2006 | 08:14 AM
pierre's Avatar
That should be 5.64 grams/second. It works out to 44.7 #/hr.
Pierre
Old Aug 22, 2006 | 10:11 AM
Witt's Avatar
Pierre
Thanks!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
