Built TVS car - WOT Cutout issues
Old Mar 12, 2013 | 09:27 PM
JapEatr's Avatar
South Central *********
ok, ID1K injectors installed and driveability is great. Im still having an issue at WOT with the car falling on its face.
with the 80s the car did this when it went over 110% IDC. Now this is happening at 75%IDC with the 1000s.
Car has built motor/ported head/cams, 2.7"TVS with ATI overdrive, E85, RSFS, ID1K, DW300
see screenshots from log.
it doesnt look like spark blowout, as there are no misfires, and no knock
wonder if my fuel pump cannot keep up, happens around 22psi boost. Wideband wasnt loggin today so never mind AFR
Old Mar 12, 2013 | 10:57 PM
InfraRedline's Avatar
For some reason your LTFT's are dropping waaaaaay down at WOT. Is the car not going into PE fully? STFT's appear to zero out.
Old Mar 12, 2013 | 11:17 PM
JapEatr's Avatar
Infra, posted my tune and full log on HPT
Have a look if you dont mind.
Old Mar 12, 2013 | 11:22 PM
Powell Race Parts's Avatar
disable the boost bypass on the side of the tvs.
Old Mar 12, 2013 | 11:26 PM
JapEatr's Avatar
I just noticed my curser moved from the peak i was trying to illustrate at time of screen capture.
John- what are you suggesting? That the bypass valve opens when under full boost wot?
This feels like fuel cut, like when kids used to bounce the stock lsj off the limiter
Old Mar 12, 2013 | 11:31 PM
The second screenshot definitely shows a decrease in boost and cylinder pressure.
Old Mar 12, 2013 | 11:34 PM
chris88z24's Avatar
Def a fueling issue.
JapEatr's Avatar
Agreed but it stops reving, the drop in boost is the gear shift after it happens i think
Old Mar 12, 2013 | 11:39 PM
JapEatr's Avatar
Built TVS Car - WOT car falls on its face at upper RPMS - HP Tuners Bulletin Board
Old Mar 12, 2013 | 11:41 PM
Hey!!!! When you limit boost in 2nd it limits in 3, 4, and 5 as well. Raise that to 100% and enjoy!!
Old Mar 12, 2013 | 11:42 PM
JapEatr's Avatar
I agree chris, but it has to be tune related i think
I have literally every fuel mod possible and quality kit, not sure what the heck would cause it
Old Mar 12, 2013 | 11:44 PM
JapEatr's Avatar
Damn if it is as simple as that im gonna flip
Question is it does it a a range of rpms from 6-7k and not 100% of the time, just then the load is really on it
Old Mar 12, 2013 | 11:48 PM
It actually looks like it starts dropping off earlier, but thats where I would start your search. You have boost limited at 6500 rpms, but I'd still start with just maxing that out again.
Old Mar 12, 2013 | 11:49 PM
JapEatr's Avatar
Ok ill try that? Anything else you see
Thanks for your help guys!
Old Mar 12, 2013 | 11:55 PM
Also, I can't tell if its you playing with the gas pedal or if your throttle is closing. If you had a good full 3rd gear pull it would be a little clearer to see. Im lookin at the log from HPT forums.
Old Mar 12, 2013 | 11:56 PM
JapEatr's Avatar
I was pedaling it to make it do it, ya ETCs in the last scrn shot are whacky
Old Mar 13, 2013 | 12:04 AM
mrbelvedere's Avatar
may be a pump problem
Old Mar 13, 2013 | 07:28 AM
area47. facebook.
Old Mar 13, 2013 | 01:26 PM
Area47's Avatar
Rent me! per hour
huh?
what arm said, and what john said. both of them. use your foot as boost control. the tvs bypass valves suck.
Old Mar 13, 2013 | 02:00 PM
JapEatr's Avatar
so you think disabling the bypass valve would stop a fuel cut? im not following
Old Mar 13, 2013 | 02:24 PM
Hockeyman's Avatar
solution - we trade cars.
Old Mar 13, 2013 | 02:37 PM
Area47's Avatar
Rent me! per hour
your injectors are not shutting off.
try those two things and report back.
whats your plugs gapped at?
Old Mar 13, 2013 | 02:40 PM
JapEatr's Avatar
"0.029 - 0.030" gap
ill remove the boost limit and test, then test without the bypass on and let you know
Old Mar 13, 2013 | 02:42 PM
Area47's Avatar
Rent me! per hour
drop the plug gap to .025.
Old Mar 13, 2013 | 06:17 PM
JapEatr's Avatar
maxxed out the 1000s
