Built TVS car - WOT Cutout issues
Old Mar 16, 2013 | 12:44 AM
  #51
574's Avatar
574
Yeah I'm only revvin to 7200
Old Mar 16, 2013 | 01:41 PM
  #52
ThexGovenor's Avatar
why limit yourself to 7200? no valvesprings?
Old Mar 16, 2013 | 03:49 PM
  #53
574's Avatar
574
No springs
Old Mar 16, 2013 | 04:57 PM
  #54
ahh got it.
Old Mar 17, 2013 | 01:08 PM
  #55
InfraRedline's Avatar
Rev it to 7400. Unless you have a lot of miles on the stock valve springs.
Old Mar 17, 2013 | 09:32 PM
  #56
JapEatr's Avatar
South Central *********
Not cutting out anymore, but right when i give it gas on a down shift, i hear a bunch of popping sounds like im blowing out the plugs
Ill try gapping my -1 step plugs to .025 and see if it improves
Old Mar 17, 2013 | 09:54 PM
  #57
chris88z24's Avatar
What kind of plugs are you using? .025 is too small IMO. .030 with NGK BKR7EIX's hit the spot for my car but YMMV.
Old Mar 17, 2013 | 10:06 PM
  #58
JapEatr's Avatar
Mine are at .030 now
Old Mar 17, 2013 | 10:46 PM
  #59
chris88z24's Avatar
What plugs are in it?
And did u change the spark dwell in HPT?
Last edited by chris88z24; Mar 17, 2013 at 10:46 PM. Reason: Automerged Doublepost
Old Mar 17, 2013 | 10:47 PM
  #60
JapEatr's Avatar
I have not changed the dwell tables
The are BRK7E
Old Mar 17, 2013 | 10:50 PM
  #61
chris88z24's Avatar
Copper? Those plugs are garbage and wear out in our cars after like 5,000 miles. Gotta use the Iridiums
Old Mar 17, 2013 | 11:04 PM
  #62
I use the copper BKR7e's and change them every 3-5k typically.
Old Mar 17, 2013 | 11:11 PM
  #63
chris88z24's Avatar
Ain't nobody got time for that
Old Mar 17, 2013 | 11:15 PM
  #64
JapEatr's Avatar
What gap infra?
Old Mar 17, 2013 | 11:19 PM
  #65
Sunburst_SS's Avatar
copper is better for performance.......irriduim/platinum lasts a lot longer.
Old Mar 17, 2013 | 11:21 PM
  #66
Gapped at .032. Small amount added to the dwell tables. Never really had blowout issues in boost though.
Old Mar 17, 2013 | 11:25 PM
  #67
JapEatr's Avatar
What is a small amount? And did you add to the whole table?
Old Mar 17, 2013 | 11:28 PM
  #68
I'd have to look again, but IIRC it was very minimal and yes to the whole table. Where are you getting the blowout? Up top at WOT?
Old Mar 17, 2013 | 11:30 PM
  #69
JapEatr's Avatar
No about 4-5 k
Sudden throttle inputs will do it as well
Old Mar 18, 2013 | 07:18 AM
  #70
Staged07SS's Avatar
Administrator
Administrator
Meh, that's debatable....
Every LSJ seems to react differently to copper & iridium plugs.
My car hated the coppers. In fact, I just tossed my BKR7E's and reinstalled my laser iridiums. Car runs much better now.
Old Mar 18, 2013 | 07:52 AM
  #71
mrbelvedere's Avatar
your ******* nuts it takes less voltage to fire a copper plug
considering they came factory with copper plugs id say your problem is within the gap I have had to run mine down to .028 to keep the blowout away
Old Mar 18, 2013 | 08:16 AM
  #72
Staged07SS's Avatar
Administrator
Administrator
Mine came from the factory with iridiums. I'm actually running my factory plug currently.
My gap is at 0.031". Runs great. No blow out even on a 32*F day @ 7.5k rpm
I wasn't getting much blowout with the coppers though, the car just didnt seem as smooth as it did with the stockers.
Old Mar 18, 2013 | 02:24 PM
  #73
Powell Race Parts's Avatar
\I am with you Staged. I run the EIX suffix in the 7's at the gap they come with and the car is awesome and the plugs last for ever.
but then I dont have that much power.
Old Mar 18, 2013 | 03:03 PM
  #74
if that's the case they may change the dwell but I have yet to see a lsj come factory with iridium
mine will not run off of them period
Old Mar 18, 2013 | 03:56 PM
  #75
Area47's Avatar
Rent me! per hour
i had to run mine at .022 gap to get it to run to 8k with modded dwell settings.
do NOT change the entire table. you will fry the coil packs.
.025 is not too small of a gap
