Bypass solenoid
Old Aug 1, 2013 | 12:04 AM
nhanson's Avatar
Bypass solenoid
I would like some info on it please. What voltage runs it? How are the vacuum lines run?
I have my 2.2 that has the M62 on it and want to limit first gear especially when I throw the 2.6 pulley on.
Old Aug 1, 2013 | 12:48 AM
mrbelvedere's Avatar
intake to vac line to back side of noid out of noid to bypass actuator
the noid is powered closed(so the blower builds boost) depowered open (blower no boost) the pcm runs it and I would think it is a 12v powered source
Old Aug 1, 2013 | 07:57 AM
Tjolley's Avatar
Depending on wat year 2.2 u have i think the pcm has the the ability to control the bypass noid. I know the Le5s do.
U would just need to find the pcm outputs and pin the boost noid to the correct terminal.
Old Aug 1, 2013 | 07:32 PM
nhanson's Avatar
2009. J Rakes said it was 5V control.
Ill look again but I thought I remember seeing S/C tables in HPT
Old Aug 1, 2013 | 08:00 PM
Tjolley's Avatar
Ya a 5v makes sence.
Old Aug 1, 2013 | 08:43 PM
5v is a reference voltage
Old Aug 2, 2013 | 07:48 PM
nhanson's Avatar
Now can I pull any 5V (lets say from the TB) or will that mess with the TB control?
Old Aug 2, 2013 | 08:13 PM
5v is ran to every sensor on the harness im sure you can but you will need a ground to run back to the pcm pin out
Old Aug 2, 2013 | 08:23 PM
nhanson's Avatar
I could run it to a switch right? and just control myself?
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
yellow dragon
Sep 28, 2015 09:49 PM
DevZX
Sep 16, 2015 06:19 PM
