Cams and springs vs P&P
Old 08-22-2011, 04:04 PM
jonnymerk's Avatar
Have the gains between these 2 options ever really been discussed.
For example: can you see just as good if not better gains from a cam and springs plus a tune as you might from a P&P and a tune?
Also what other changes might be gained other than peak numbers?
For example my lsj is on a large turbo set up but stock motor otherwise.
More people are camming now and I'm confident in my tuner as long as the cam options available do work when put in right.
Old 08-22-2011, 04:08 PM
ItalianJoe1's Avatar
Doesn't really make sense to do one without the other IMO. If you are going through the work of pulling the head, might as well do it all right. Proper porting and flow work gives gains much the same as cams, shifts powerband and such. Springs in themselves do not gain power unless they are combatting excessive valve float, but they allow you to rev higher and make more power if the rest of the setup can handle it.
Old 08-22-2011, 06:15 PM
jonnymerk's Avatar
I know the springs dont add power but you cant really do cams without changing those things.
I have a spare head so I wouldnt be putting myself out. And one with out the other is more of a budget thing.
I really wanted to know if there is more to gain from a cam then a P&P. Basically performance and price comparison.
Old 08-22-2011, 06:45 PM
Leafydialupking's Avatar
I'd rather be ported before I went with cams. That way I would take my flow bench numbers and give them to my cam designer along with my header and intake manifold info goals and whatnot and get the cam designed for my application that'll blow any off the shelf cam out of the water for slightly more expense.
Old 08-23-2011, 02:19 AM
InfraRedline's Avatar
Having my head ported by Euthanasia completely changed my car....in a good way
05-28-2022 03:47 AM
HEATON
10-16-2015 07:21 PM
Tupp
09-30-2015 08:18 PM
nathan112i
09-30-2015 07:12 PM
Dylan Johnson
09-30-2015 08:57 AM
Quick Reply: Cams and springs vs P&P
