Car Does not shift at WOT
It shifts fine 1,2,3,4,...then when going from 4th to 5th at wot it won't shift into gear. I've heard about a drill mod on camaro/t.a that you drill out the clutch line...anyone else know any fixes? Kind of annoying get going then cant shift into 5th.... its a bummer... Car is under warranty should i just take it to them and tell them to fix it?
Bone stock... 06 SS/SC. 5th is only out at wot shifts perfect at anything below 5200 rpm in 4th...once around 5300 its BAM... Won't shift cant get it into gear...Can try up to 5 times.
dealer is going to say they cant test that and to slow down. the rev limiter would come on at 128 or 144mph (depending if your stock or stage 1 or 2).
id guess its an inherent design flaw in the transmission but they arent gonna fix it because it was never designed for that. its just like the old getrags in the v6 cavaliers, if you rev over 7500 with 200+ hp, it wouldnt shift because the case distorts and flexes, its impossible to get into gear until the rpm drops bellow 7500.
well i've raced guys around here with stock/stage 2 cars and they have no problem shifting into fifth above 5500 ish rpms... Mine just wont go in till you drop below that mark. I might try that fix that the ta/camaros are using
Turbo Johnny
Feb 21, 2019 09:41 AM
SS_2009_TC
Sep 11, 2015 05:41 PM
