car doesnt get up to operating temp.
Old Dec 3, 2009 | 09:27 PM
nickha's Avatar
i have an 06 cobalt ss/sc. its completely stock, in the winter it doesnt get up to operating temp. i let it warm up for 5-10 mins and it barely gets to 100 degrees. even after i start driving it barely gets over 120 and it seems to lag alot anyone have this problem?
Old Dec 3, 2009 | 09:36 PM
JL-KA's Avatar
Higher temp thermostat
/thread
Old Dec 3, 2009 | 09:41 PM
sundevil07's Avatar
lol you don't need a higher temp t stat, yours is stuck open you need an oem replacemtent
/thread
Old Dec 3, 2009 | 09:42 PM
NOLAGSS's Avatar
mines doing the same thing but mine gets up to around 140-160 my check engine light is also on for a p0428 thermostate code no big deal to me i still have heat and when it gets above 50 deg outside it goes off
Old Dec 3, 2009 | 09:44 PM
damien's Avatar
Mine takes a good short drive to get up to temp. Maybe about 10 minutes actual driving time
Old Dec 3, 2009 | 09:55 PM
selfinfliction's Avatar
/thread
you could do what he says, or you could re-route the top coolant tube directly into the supercharger inlet, this method will definitely get your car up to operating temp
Old Dec 4, 2009 | 12:06 AM
venum_us_2002's Avatar
is this the part he needs?
http://www.gmpartsdirect.com/catalog/frameset.cfm
Old Dec 4, 2009 | 12:36 AM
rckrz6's Avatar
thermostat
Old Dec 4, 2009 | 01:16 AM
sundevil07's Avatar
lol wow, so you dont let your car get up to operating temp huh? hope youre not doing any spirited driving. whats the winter rating on your oil? ex: 10w30, 5w30
lawls
Old Dec 4, 2009 | 01:38 PM
BigJake's Avatar
Mine is having the same Problem.
Old Dec 4, 2009 | 08:59 PM
JL-KA's Avatar
/thread
You don't know that...my answer has just as much validity as yours.
Old Dec 5, 2009 | 01:55 PM
sundevil07's Avatar
lol, ecotoecs are designed to run most efficiently in the 180-188* range, they come with a 180* thermostat for a reason. What degree t-stat would you suggest? just curious
Old Dec 5, 2009 | 02:38 PM
rollingboostedss's Avatar
what is the weather like where you are in the cold weather here my car will only get to about 160*
Old Dec 5, 2009 | 04:24 PM
Karlen89's Avatar
When it's cold out, mine still gets to 185* within a few minutes of driving.
Just curious, how many miles do you have OP?
Old Dec 5, 2009 | 06:27 PM
i only have about 27k on my car but it has always done this since i've owned the car
Old Dec 5, 2009 | 07:13 PM
Karlen89's Avatar
That's odd. I don't know what would cause that. I'm on 92k, stock thermostat. No problems here.
Old Dec 5, 2009 | 07:36 PM
JL-KA's Avatar
If he's always had this issue and it's only in the winter time I doubt its getting stuck open. He can try what you suggested and replace with oem...if that doesn't work then he can try what I suggested and get one with a higher temp rating.
And fyi mine has always run around 195-205 since the day I bought it new.
Old Dec 5, 2009 | 09:12 PM
jazzyjames1371's Avatar
ive got an 05. mine did the same thing after owning it for 2 yrs. its just a bad thermostat, thats stuck wide open. it wont realy hurt your engine is what the dealer said to me, and it was covered under warranty.
Old Dec 5, 2009 | 10:35 PM
sundevil07's Avatar
let us know whats wrong when you find out
Old Dec 5, 2009 | 11:03 PM
Maven's Avatar
If youve got an 05-06 and under 60k(100k miles for newer) miles just go to the dealer and get a new thermostat, thats for the group of you with the issue
Old Dec 10, 2009 | 06:52 PM
nickha's Avatar
my car only has 52000 so its out of warranty and its about 40 degrees out now and barely gets to 120 degrees. i bought a new thermostat but changing it out is a pain.
Sean Cummings
Jan 8, 2020 10:17 AM
chefhhr
Oct 26, 2015 10:36 PM
vjoel2011
Oct 2, 2015 12:11 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
