Car will not start, help!
Old Sep 3, 2011 | 10:11 AM
j.man1503's Avatar
Hey guys, so I feel like a dummy. I performed the following to today to attempt to perform the air box mod and replace my fuel filter, only to find that my car doesn't start now.
1. I took the air box off and disconnect the sensor on it (I think the MAF, right?)
2. Performed the mod, but the tubing back. (I forgot to hook the MAF back up)
3. Disconnected the relay switch for fuel pump.
4. Disconnected my Negative batt. terminal for 10 minutes, then reconnected.
5. attempted to start car to relieve pressure in fuel system, didn't start.
6. Remember that I didn't connect my MAF, and connected it.
7. Attempted to start, did not start.
What's the deal, any advice for this ameatur?
Thanks
Old Sep 3, 2011 | 10:20 AM
ive heard before on some cars u gotta wait for a bit after battery was disconnected.. are u getting power? like lights on, fuel pump runnning and stuff? just wont start?
Old Sep 3, 2011 | 10:22 AM
CTcar's Avatar
Did you try hooking the fuel pump relay back up and starting?
Old Sep 3, 2011 | 01:41 PM
Sharkey's Avatar
i had that happen to me way back when i did a fuel filter. pulled the relay, started the car till fuel pressure was 0, changed the filter, put the relay in and it wouldnt start. i cant remember what it was but i think you can put the relay in backwards and it will cause the fuel pump not t come on.
does the pump prime when you turn the key on?
Old Sep 3, 2011 | 01:54 PM
bamaboy22's Avatar
Prime it 3 times yo
Old Sep 3, 2011 | 04:44 PM
j.man1503's Avatar
I did put the relay back in, haha. I did not put it in backwards, so that possibility is eliminated. However, I did not prime it. How do I do this? Is it as simple as pumping the gas pedal or something more? Thanks so much for responding guys, can't wait to find the answer!
Old Sep 3, 2011 | 04:45 PM
j.man1503's Avatar
also, I do get electrical power, the battery turns and turns the engine, but it never combusts.
Old Sep 3, 2011 | 04:51 PM
firefighter404's Avatar
to prime i believe you turn on the car and let the pump prime turn the car off and repeat three times.
Old Sep 3, 2011 | 04:58 PM
j.man1503's Avatar
Wonderful, I'm going to try it now, thanks so much!
Old Sep 3, 2011 | 05:04 PM
Chevycobaltss3's Avatar
hey bro your issue sounds like fuel. If your maf was bad or disconnected or somthing else like that itll start but die soon after. make sure you didnt blow a fuse and relays are al good.. make sure your pump is priming itself. Oh yeah there is a loiusville thread btw if you have question you can call me im the local guy!! hahahaha good name i think.. my cell is 270-505-3212
Old Sep 3, 2011 | 05:05 PM
j.man1503's Avatar
Still did not start
Okay, so here's what I did:
- Turned key to on position for 15 seconds
- Turned key to off position for 5 seconds
- Repeat 2x (for a total of 3)
Then, I attempted to start the car, it actually combusted a little, but then died.
I repeated this entire proces twice more. Any thoughts, it's probably something really simple, but I can't get it!
Old Sep 3, 2011 | 05:12 PM
ok if it combusts then there is fuel. Somewhat, go to the schrader valver and turn the car to the on position if there is fuel pressure the schrader valve will spit fuel out... If no fuel you know the fuel pump is not kicking on. Another thing to check is the ip signal fuse fuel pump fuse and other relas and fuses. If you took the maf out it can be in backwards make sure the arrow points straight up!
Old Sep 3, 2011 | 05:23 PM
j.man1503's Avatar
Okay, I'll go and do those now. I didn't take the MAF out of the tubing for the intake, I simply disconnected it's dongle so that I could perform the airbox mod. Where is the schrader valver on the cobalt?
Old Sep 3, 2011 | 05:36 PM
87gn06gto07irl's Avatar
Retrace all your steps. If it ran before, it's 99% likely it's something that was done. If not, do a fuel pressure test and check spark.
Old Sep 3, 2011 | 06:08 PM
lsjion's Avatar
check you inj fuse in the under hood fuse box, also try starting it with the gas all the way to the floor, it'll make the car go into clear flood mode and may clear fuel out if for some reason it's flooded. try both
Old Sep 3, 2011 | 06:37 PM
LilHaile's Avatar
Mine does this after filling up with fuel.. Not sure of what model you have but on my 08 T/C the Fuel Canister Purge Valve is junked. To temporarily fix this try unplugging that sensor. It won't hurt anything just throws the check engine light. Not sure if this is your issue but def has the same effects of it not starting. I could however get mine to start if I held the pedal to the floor and just kept cranking it.
https://www.cobaltss.net/forums/prob...t-till-193735/
Old Sep 3, 2011 | 07:36 PM
j.man1503's Avatar
Thanks again guys, finally got it started after lots of priming!
Old Sep 3, 2011 | 11:47 PM
yea if your pump was completly empty and you depresurrized the lines it takes a little while to feel them back up.
Old Sep 3, 2011 | 11:51 PM
yeah i helped him get running!!!! lol He lives like 30 mins by me and i didnt even know that, great guy i am hahaha
Old Sep 4, 2011 | 02:22 AM
06blackbalt's Avatar
pump relay is in the wrong spot
Old Sep 5, 2011 | 01:58 AM
what was it
Old Sep 5, 2011 | 12:52 PM
sternerG85SC's Avatar
make sure you didnt put your fuel pump relay fuse in backwards. i know it looks like its upside down when its in compared to identical fuses on the other side of the fuse box. prime it 2-3times ( just turn the key. should hear the pump pressurizing) if you cant do that its a sometype of electrical problem. but i think you have the fuse i nbackwards or in a empty slot. i did the same thing when i changed my fuel filter 3weeks ago. there should be a fuel pump how-to with pics of the fuses n such
hawkssoccer11
Sep 30, 2015 12:14 PM
Wind
Sep 11, 2015 06:57 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
