CEL and Bad Acceleration
Old Aug 31, 2007 | 10:11 PM
fsickness's Avatar
So I get off work today and go to the store, on the way my CEL comes on and I can notice a power loss. So I say screw the store and go to my local chevy dealership. They scan the car and it gave them a trouble code of P0172, (fuel system rich) and something else about a misfire code. They said that it was not one particular cylinder mis-firing but they would take "turns".
First off has anyone ever herd of this?
I am kinda freaked out because this dealership has only sold 2 SS/SC's and did not have another on the lot. I got mine about 50 miles away.
So the dealership took and preformed a Fuel Injector Service and added some **** to my gas tank and sent me on my way. Problem is still there. So any suggestions? Besides taking it to another dealership. I think they just did not want to look into it that much, they put 35 miles on my car in about 90 min and all I have to show for it is a piece of paper that sayd they put4 miles on it.
Do you all think my spark plugs could be bad and they are causing a misfire?
Please help me in anyway you all can, I really appreciate it.
Bump for some info please
Old Sep 1, 2007 | 10:53 AM
fsickness's Avatar
So no one can give me some advice, got up this morning to go to work and the CEL came back on while the car was warming in my drive way and still the same "power loss" but no limp mode. Anybody?
Old Sep 1, 2007 | 11:05 AM
2.0freakotec's Avatar
had the same problem u need to go to the dealership and get ur car reflashed with their tech 2 tool it might cost u about 125 but dont pay more than 130 our cars have 7 upgrades. Get it done ASAP!!!
Old Sep 1, 2007 | 11:30 AM
Sales@rebelautoworxs's Avatar
Get them To Reflash the Car to the newest PCM firmware. It should clear up the codes your having. You can also swap in a set of plugs in there aswell.Fairly cheap too do aswell.
The Cars run fairly rich from the factory. I've set missfire codes before with rich conditions.
Old Sep 1, 2007 | 11:43 AM
fsickness's Avatar
Thanks for the information and I think I will change out the plugs either way...any recomendation on type of plug and what is the recomended gap?
Ok never mind on the type found that but gap?
Also the car is still under war. so the reflash is free right?
Old Sep 1, 2007 | 12:09 PM
They shouldn't charge you.
But they're dealers...
Old Sep 1, 2007 | 12:16 PM
about the gap some people say leave them at 40 cause the tip is so brttle, but i have seen people gaping them between 36-40 and yes u will have to pay for ur reflash prob. like i said 120-130 and go to zzp and get ur plugs there NGK they are great and good luck
Old Sep 1, 2007 | 02:23 PM
korax123's Avatar
What grade fuel do you put in the car. You better be putting in premium.
Old Sep 1, 2007 | 02:35 PM
Misery5567's Avatar
That's all I run in mine.
Old Sep 1, 2007 | 02:41 PM
skymynx's Avatar
go to your local napa. theyll have ngk plugs
Old Sep 1, 2007 | 02:49 PM
fsickness's Avatar
YES I run premium fuel and I usually get it from Shell, never had anything else in there besides Octane Booster about a month ago when I went to the drag strip but did not notice any difference so it was in my eyes a waste of money. So I just ordered the plugs but am prob going to go buy some anyways just so I have an extra set for somewhere down the road or something. So the earliest I can take my car in again is a week from monday because I am in the navy and we are leaving for a few days. So I will make sure I get on top of that as soon as I get Back. Thanks for the help guys!!!!!
Old Sep 4, 2007 | 11:19 AM
skymynx's Avatar
im having the same problem. gonna check out my o2 sensors. i think somethings up with that. changed sprak plugs to ngk 6 series
Old Sep 4, 2007 | 12:03 PM
Area47's Avatar
Rent me! per hour
never run octane booster.
ngk stock number 6097. gap them to .36
Old Sep 4, 2007 | 12:13 PM
rnjmur's Avatar
Octane booster is a complete waste of money. You will see at BEST maybe a .5 increase in octane.
Old Sep 4, 2007 | 07:01 PM
skymynx's Avatar
what kind of octane booster do you use though. torco racing fuel is a high quality grade.
Old Sep 14, 2007 | 12:26 AM
fsickness's Avatar
Well the car is back in the shop....talked to them about the 37 miles when they only loged 4 and the car is even worse for some reason. It is almost as if I am driving a auto with the lag that is there and I pulled a spark plug 5 days after I replaced them and it did not even look as if they were replaced. So dropped off the car yesterday and check on it tom. Hope all goes well with it and they dont say they need it iver the week end
Old Sep 14, 2007 | 01:09 PM
rukkee's Avatar
Mine has the same random misfire , they did the whole fuel injector cleaner route but it still does it . Mine will never misfire when on the gas , only when its winding down from rpm or idling. They ordered a cat and i'm having it installed Tuesday. I'll see how it goes ,BTw mine has all the latest pcm updates and it didn't change . Mine never threw a cel either , i just checked it myself cause i felt it .
Other things ive done .... changed plugs , changed gaps .30 .35 .40 , fulled my K&N cleaned the maf and intake tube all the way to the blower (found a little oil from the pcv system ) , cleaned the throttle body then replaced the original factory filter with the uncut airbox . I wish it would set a cel that way i would know which route to take . Driving me nuts , but i havent noticed a bid power loss. Good luck with yours .
Old Sep 14, 2007 | 01:11 PM
Jimmys2007CobaltSS/C's Avatar
how much does a reflash cost...cause i need one to ...my engine light has been on for a week
Old Sep 14, 2007 | 01:57 PM
bamaboy22's Avatar
i had the same problem from my CIA threw the same codes and did the same power loss
Old Sep 17, 2007 | 04:10 PM
fsickness's Avatar
So the car goes back into the shop tom to get worked on they are saying it is the MAF sensor that is bad but this is the second one in 4 months. Also changed the plugs and nothing changed. I am trying to figure out if it could be the CAI that is causing this but I never drive in the rain. If it is raining I tend to drive the Eclipse. Do you all think there could be a sister problem issue? They also said they did the latest PCM flash but I dunno. I want to lemon this car and see if they will give me another but I have had it for 9 months and it has been in the shop atleast once every month. Love the car to death just hate the problems it is giving me. Any more suggestions?
Old Sep 19, 2007 | 10:43 PM
fsickness's Avatar
So an update...changed MAF sensor....no change.....updated PCM.....no change still miss-firing in cylinder #4....Chevy still has the car and I am driving a Impala.....I want my car back....Any suggestions on what could be wrong? Dealership is taking suggestions.....
Old Sep 19, 2007 | 11:59 PM
rnjmur's Avatar
Misfire on cylinder 4... maybe an injector problem? Have they done a compression test? Checked the spark plugs? Possibly a broken rocker arm? I am just throwing out anything here... lol
Old Sep 20, 2007 | 12:31 AM
Novajoe's Avatar
Try switching your cai back to stock. The new piping changes the flow characteristics in the intake and throws the readings for the maf off. Our mafs are really picky on these cars and very sensitive. Distance from the tb, air moving on one side of the intake rather than the other when it was stock, both could throw off the maf readings.
turbochargedss2012
Sep 20, 2023 12:17 PM
Oct 13, 2015 09:32 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DocSvensk
Sep 27, 2015 02:24 PM
