CEL: EVAP System?!?!
Old Sep 5, 2008 | 08:36 PM
Peterson101's Avatar
Sooo about 3 weeks ago I got a CEL and got it scanned. Cameback the EVAP system. Replaced the gas cap and disconnected the battery to reset it... well it cameback. Any suggestions?
Old Sep 5, 2008 | 08:37 PM
XM15's Avatar
Now you need to tighten the cap.
Old Sep 5, 2008 | 08:38 PM
I have, I've reset the system 3 times and it has comeback still, what else could it be?
Old Sep 5, 2008 | 08:40 PM
XM15's Avatar
It might be a hose then. If you have warranty, take it to the dealer.
Old Sep 5, 2008 | 08:41 PM
I have warranty for drivetrain, nomore bumper to bumper.
Old Sep 5, 2008 | 08:43 PM
XM15's Avatar
I believe there are several EVAP codes. Are you throwing just one or several of them?
I found this:
"If you first get a P0442 or P0456 then a while later get a P0455 it is a sign a hose is going bad. If you get a P0455 (large leak) at the outset it more likely a stuck valve or a hose which came loose.
A smoke machine is the fastest way to finds leaks in these systems but not a common tool for do it your selfers."
Old Sep 5, 2008 | 10:16 PM
NexTnmE's Avatar
I had the same thing last month. Turns out it was the vent tube. What code is it?
This might help...
https://www.cobaltss.net/forums/general-cobalt-68/three-trips-dealer-spiders-nest-127844/
Old Sep 6, 2008 | 12:42 AM
Ryze's Avatar
code be vent solenoid stuck open, they are located on the rear of the vehicle near the charcoal canister out in the open. the elements get to it and causes it to fail..
Also any leaking hose in the fuel system will cause a CEL..
Pretty much no one on the internet is going to be able to pinpoint it out, they can tell you maybe its this or maybe its that, but the only way to know for sure is to get it smoked, bring it to a shop capable of this
Old Sep 15, 2008 | 10:36 PM
I finally took it to the dealership to see what was up... seems my purge valve is stuck open. It is going to cost 174 to fix.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
nathan112i
Sep 30, 2015 07:12 PM
