Cel P0420
Cel P0420
My interceptor gauge says I have a code, and I have the CEL. The code is obviously P0420. I am assuming it is because I do not have a catalytic converter. Is this correct, or is there/could there be another problem?
it can't be clogged...i don't have one.... my cat is sitting in my trunk guys. Maybe i miss typed this.
I do not have a CAT on my car. Am I having the P0420 code because of me not having a cat, or is it for something else?
Yes its just a big change flow in air so its hitting that o2 sensor and its not use to that.. theres an aftermarket 02 sensor i think you can get and there wont be a code for not having a cat
Great, so I am having this CEL/Code because the car not having the cat. I can clear the code with the interceptor however it will come back. Not to big of a deal. I am going to purchase HPTUNERS so I will be able to permanently kill this code =D.
My next question is. I am soon having a 3inch header/downpipe/magnaflow cat being put on. Will I throw the same code, or will I throw a different code, or will i NOT have a code because the cat is there?
Doc - I am not sure if the sensor is still there or not. If you are talking about the o2 sensor, I believe they put it back where it belongs. Like, my exhaust is a custom made 3 inch exhaust, so I believe they made an o2 bung and welded it in or whatever.
Last edited by Zach06CobaltSC; Jun 14, 2008 at 09:03 PM. Reason: Automerged Doublepost
all you will have to do is unplug your battery for no more than 10 minutes and it should reset itself.
Thatotherguy - correct, however it will come back in like 10 minutes if i reset the battery.
I plan on getting a custom tune in july once all my parts are installed, and hopefully will get close to the 300hp mark to the wheels, thats the goal.
I am also buying hptuners here shortly just so I can change little things myself, or with the help of the people online.
yeah what i meant was a 02 sensor that wont throw a code for having no cat... sorry if i made it sound weird lol
Oh don't get me wrong, it doesn't bother me having the CEL on currently. I just wanted to make sure the code was because I didn't have a cat. I wanted to make sure it wasn't because my engine was gonna blow up lol. I don't know much about codes, and I couldn't really find anything with the search engine.
thatotherguy - yea, the o2 sensors are there and in place and all good to go, i just dont have a catalytic converter. I had the shop take it off when i was getting my 3inch exhaust done.
My next question though, is when i put my header/downpipe/cat on will i have this same code?
Currently I am having this code because I dont have a cat. So if i install the magnaflow cat, along with my headers and downpipe, I should not have a code. Correct?
Last edited by Zach06CobaltSC; Jun 14, 2008 at 09:15 PM. Reason: Automerged Doublepost
No the code will go away. the CEL only comes on if you dont have a cat and if you do put a cat on it then it will be like stock with no codes
Sweet, that will be great. I ordered a 3inch header and downpipe along with a magnaflow cat from zzp. So then once thats installed, hopefully on wednesday/thursday i will not have the p0420 code.
Great. Maybe then I won't have to worry about that cel. Do you guys know if the Injen Cold Air Intake will make me throw a code?
Also. Did I choose the right setup for my headers/downpipe/cat. Is zzp good? I ordered the combo with 1 3/4inch high temp paint, magnaflow cat, mild steel downpipe, 3 inch downpipe, with 3inch bolt in exit. Add extra o2 bung for wideband. Send me a prepaid return label.
So did I make a good choice on the header/downpipe/cat combo?
