Cel P0420
Old Jun 14, 2008 | 08:48 PM
Zach06CobaltSC's Avatar
Cel P0420
My interceptor gauge says I have a code, and I have the CEL. The code is obviously P0420. I am assuming it is because I do not have a catalytic converter. Is this correct, or is there/could there be another problem?
Old Jun 14, 2008 | 08:52 PM
madmark's Avatar
gato =\
Old Jun 14, 2008 | 08:54 PM
thatotherguy's Avatar
Nope p0420 is low cat efficiency.
madmark's Avatar
which means leak or bad cat
Old Jun 14, 2008 | 08:56 PM
I have no CAT. I took out my cat. So isn't this code because I do not have a cat?
Old Jun 14, 2008 | 08:59 PM
it can't be clogged...i don't have one.... my cat is sitting in my trunk guys. Maybe i miss typed this.
I do not have a CAT on my car. Am I having the P0420 code because of me not having a cat, or is it for something else?
Old Jun 14, 2008 | 09:00 PM
Yes its just a big change flow in air so its hitting that o2 sensor and its not use to that.. theres an aftermarket 02 sensor i think you can get and there wont be a code for not having a cat
Old Jun 14, 2008 | 09:01 PM
Doc's Avatar
Doc
what happened to the sensor..??
These are the errors/codes you can get without changing/disabling the codes with HPTuners
  • P0036
  • P0054
  • P0136-P0141
  • P0420
Old Jun 14, 2008 | 09:03 PM
Great, so I am having this CEL/Code because the car not having the cat. I can clear the code with the interceptor however it will come back. Not to big of a deal. I am going to purchase HPTUNERS so I will be able to permanently kill this code =D.
My next question is. I am soon having a 3inch header/downpipe/magnaflow cat being put on. Will I throw the same code, or will I throw a different code, or will i NOT have a code because the cat is there?
Doc - I am not sure if the sensor is still there or not. If you are talking about the o2 sensor, I believe they put it back where it belongs. Like, my exhaust is a custom made 3 inch exhaust, so I believe they made an o2 bung and welded it in or whatever.
Last edited by Zach06CobaltSC; Jun 14, 2008 at 09:03 PM. Reason: Automerged Doublepost
Old Jun 14, 2008 | 09:04 PM
you can go get a tune and they can disable it foreverrr.
all you will have to do is unplug your battery for no more than 10 minutes and it should reset itself.
Old Jun 14, 2008 | 09:08 PM
Thatotherguy - correct, however it will come back in like 10 minutes if i reset the battery.
I plan on getting a custom tune in july once all my parts are installed, and hopefully will get close to the 300hp mark to the wheels, thats the goal.
I am also buying hptuners here shortly just so I can change little things myself, or with the help of the people online.
Old Jun 14, 2008 | 09:10 PM
FASTL61's Avatar
i was told the downstream o2 senser has nothing to do with fuel trim,all it does is monitor the cat (p0420)....so you can run with no cat,throw the code and still maintain proper AFR's
Old Jun 14, 2008 | 09:11 PM
Wink
It comes back somewhere around 80 miles or less. but if your getting hp then you wont have to worry about anything. any codes that show back up you can delet them
Doc's Avatar
Doc
Its a simple fix to do when you have HPTuners.
It is annoying to turn the CEL off but you won't suffer if you don't turn it off.
Old Jun 14, 2008 | 09:13 PM
yeah what i meant was a 02 sensor that wont throw a code for having no cat... sorry if i made it sound weird lol
Old Jun 14, 2008 | 09:15 PM
Oh don't get me wrong, it doesn't bother me having the CEL on currently. I just wanted to make sure the code was because I didn't have a cat. I wanted to make sure it wasn't because my engine was gonna blow up lol. I don't know much about codes, and I couldn't really find anything with the search engine.
thatotherguy - yea, the o2 sensors are there and in place and all good to go, i just dont have a catalytic converter. I had the shop take it off when i was getting my 3inch exhaust done.
My next question though, is when i put my header/downpipe/cat on will i have this same code?
Currently I am having this code because I dont have a cat. So if i install the magnaflow cat, along with my headers and downpipe, I should not have a code. Correct?
Last edited by Zach06CobaltSC; Jun 14, 2008 at 09:15 PM. Reason: Automerged Doublepost
Old Jun 14, 2008 | 09:21 PM
No the code will go away. the CEL only comes on if you dont have a cat and if you do put a cat on it then it will be like stock with no codes
Old Jun 14, 2008 | 09:22 PM
Sweet, that will be great. I ordered a 3inch header and downpipe along with a magnaflow cat from zzp. So then once thats installed, hopefully on wednesday/thursday i will not have the p0420 code.
Old Jun 14, 2008 | 09:24 PM
yepp correct
Old Jun 14, 2008 | 09:29 PM
Great. Maybe then I won't have to worry about that cel. Do you guys know if the Injen Cold Air Intake will make me throw a code?
Also. Did I choose the right setup for my headers/downpipe/cat. Is zzp good? I ordered the combo with 1 3/4inch high temp paint, magnaflow cat, mild steel downpipe, 3 inch downpipe, with 3inch bolt in exit. Add extra o2 bung for wideband. Send me a prepaid return label.
So did I make a good choice on the header/downpipe/cat combo?
turbochargedss2012
Sep 20, 2023 12:17 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
Dustin24
47
Feb 12, 2016 04:10 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
