Cheapest place to buy methinjection?
Old Feb 13, 2008 | 11:07 PM
invisible's Avatar
I saw a vendor on here earlier today or late lastnight and it came with the controller and a few other nice things and it was only like 250.00. Just wanted to get some info on where it is the cheapest. thanx
Old Feb 13, 2008 | 11:24 PM
2K5SS/SC?'s Avatar
Are you talking about this?
http://www.alcoholinjectionsystems.c...duct_info.html
or
There is also Snow Performance too:
Universal kit w/ boost switch:
http://www.snowperformance.net/product.php?pk=6
Cobalt Specific with Progressive Controller (PRICEY):
http://www.snowperformance.net/product.php?pk=48
The Devil's Own universal kit or the universal kit w/ a bottle still works out to be cheaper than both kits as they use a boost switch for the kit. The Devil's Own progressive kit is only $330
Universal kit:
http://www.alcohol-injection.com/wat...iversal-8.html
Progressive kit:
http://www.alcohol-injection.com/wat...age-2-106.html
Old Feb 13, 2008 | 11:39 PM
invisible's Avatar
Which one do you recommend. I was going for the devils own 330.00 system.
Old Feb 13, 2008 | 11:42 PM
spaz's Avatar
I got the devils own kit you probably don't need the progressive kit if you want to save a couple bucks. The progressive one uses the map signal
Old Feb 14, 2008 | 01:33 AM
2K5SS/SC?'s Avatar
If you get the Progressive kit it requires you to tap into the wire harness for a signal from the MAF sensor just as a heads up. Then you will have to dial in the settings with test/fine tune of the controller.
I personally bought the Devil's Own universal kit and the 2 quart bottle because there is no real need for the Progressive controller considering how fast the blower makes boost. Just set the activation switch to 8-10psi and your done. No messing around with the stock wiring harness for a signal. It's fairly easy to install and includes everything you need and they are all high quality parts. Mine is the second kit from Devil's Own I've personally installed and they work awesome!
My buddy spent a ton of money on his Snow Performance kit for his WRX, and was pissed when I got my Devil's Own kit for half the price and it works better than his does.
Old Feb 14, 2008 | 01:35 AM
lsjwannabe's Avatar
i have the progressive kit
Old Feb 14, 2008 | 01:44 AM
ralliartist's Avatar
Cooling mist sells their products on ebay. You can get a whole kit with a tank for 200!
Old Feb 14, 2008 | 01:48 AM
firestorm's Avatar
there is a place called alky-control
search for that on the net. might be usefull....
Old Feb 14, 2008 | 11:43 AM
KillerNutz's Avatar
Aqua Stealth FTW!
Old Feb 14, 2008 | 11:56 AM
Kibosh3's Avatar
lies!
...no really?
Old Feb 14, 2008 | 11:57 AM
invisible's Avatar
Is there a huge difference between the cobalt specific models and the universal??
Nevermind..reading>me
Old Feb 14, 2008 | 12:33 PM
KillerNutz's Avatar
most of the brands use the same Shur-flo alcohol pump too.
Old Feb 14, 2008 | 12:34 PM
invisible's Avatar
So meth would be more effective then going with a h/e or dual pass then right??
Old Feb 14, 2008 | 12:35 PM
M-Dub's Avatar
Aquastealth! $179.99
Yes on both accounts, but the frount mount H/E works well too! Dual pass is minimal at best!
Old Feb 14, 2008 | 12:40 PM
invisible's Avatar
Would there be any big sacrifice in quality if i go with the cheaper one. For example Aquastealth???
Old Feb 14, 2008 | 12:42 PM
M-Dub's Avatar
I'm running it on my car right now! The only difference on my setup is I used a better boost swtich and some tweaks from Area47!
But I know 2-3 other guys running that kit by itself and had no problems! It's actually very high quality! SHUR-FLO pump, metal quick connectors, and everything the other kits come with too!
Old Feb 14, 2008 | 12:44 PM
an0malous's Avatar
*chuckle*
you already know the answer to that question.
Old Feb 14, 2008 | 12:46 PM
invisible's Avatar
I think im going to order it in a few mins. I have one question? What kind of pump trigger should i get with my mods. There isnt going to be any tuning on my car for awhile to if that helps. I just want it to kick in after 9 psi or so.
Old Feb 14, 2008 | 12:47 PM
M-Dub's Avatar
Originally Posted by an0malous
*chuckle*
In the standard non progressive kits! What would be different? Pump, relay, connectors, tubing and wire! Not followin' your logic there!
invisible's Avatar
*chuckle*
Yea thats what i though, But he says its good quality so i might give it a try or go with devils own.
Old Feb 14, 2008 | 12:48 PM
M-Dub's Avatar
The kit is setup factory at 8 psi, mine kicks on at 4psi! But you should get tuned with it to actually notice the difference!
Old Feb 14, 2008 | 01:02 PM
invisible's Avatar
I mainly wanted it to keep my IAT's cooler for now.
Old Feb 14, 2008 | 01:04 PM
M-Dub's Avatar
It'll deff. do that!
dennis69
Oct 20, 2015 04:49 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Tupp
Sep 30, 2015 08:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
