check engine light help
Old Dec 28, 2010 | 10:54 PM
Blue05SS's Avatar
Unhappy check engine light help
k so i just got my car put back together after replaceing the vavles started it up it runs good it hasnt been wanting to start on the first try but other than that its runs good but i keep getting a check engine light for: camshaft to crankshaft correlation bank 1 sesor B ive reset it and it just comes back i lined up the timing marks right i double checked it before i sealed everything up any ideas???
Old Dec 29, 2010 | 08:37 AM
Blue05SS's Avatar
no one has any ideas??
Old Dec 29, 2010 | 08:39 AM
user 70823082's Avatar
Take it too an advanced auto parts or auto zone and they will scan the code for you for..wait for it..FREE
ezekielguy86's Avatar
I had a problem with mine last week after replacing the head gasket. I was the cam sensor unplugged. I was getting check engine light and took couple tries to start.
Old Dec 29, 2010 | 09:14 AM
mrbelvedere's Avatar
^^ what he said or the cam sensor is not timed correctly
Old Dec 29, 2010 | 09:24 AM
Blue05SS's Avatar
i have acess to a scanner and it says camshaft to crankshaft correlation bank 1 sensor B
ive already checked all my connections and there all hooked up
see this is where i get confused cuz i lined everthing up on the marks i dont understand what would make it lined up correctly?
Old Dec 29, 2010 | 09:27 AM
ok bring number 4 cylnder up on tdc compression stroke align the timing marks on the cps housing 11 oclock
Old Dec 29, 2010 | 09:29 AM
rnjmur's Avatar
Did you make sure you did the timing proceedure correctly? Did you make sure the camshaft sensor is lined up correctly? It definitely sounds like a timing issue of some kind.
Old Dec 29, 2010 | 07:37 PM
Blue05SS's Avatar
yes on the timing however i didnt know about the cam sensor how do i check that???
Old Dec 29, 2010 | 07:49 PM
ok bring number 4 cylnder up on tdc compression stroke there is a mark on the hex wheel and a mark on the housing line those up and install
Old Dec 29, 2010 | 09:13 PM
Blue05SS's Avatar
k thx ill give that a try tommorow
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
