Clutch issues
Old Aug 17, 2007 | 12:06 AM
sunfirejoe's Avatar
Clutch issues
the bastard wont bleed at all, we do the process, we watched the bubbles, and still nothing, i got lots of pedal pressure but it will not go into gear no matter what i do, help
Old Aug 17, 2007 | 08:08 AM
Sales@rebelautoworxs's Avatar
We had a Mechanic install the fly wheel on crooked once. I hope everything is mated up between the clutch and the flywheel nice and flat.
Other than that did you resuse the stock slave cylinder/throwou bearing ?
Old Aug 17, 2007 | 10:32 PM
sunfirejoe's Avatar
yah reused stock throw out bearing, i think thats me issue, the has lots of pedal pressure now, but wont go into gear this blows . so close to driving yet so far
also another issue, i did not put my rubber cap on my line that attaches to the tranny, is there any way that i may just have only air in my throw out bearing, if so how do i just know if theres fluid in it, i dont have ny air in my clutch at all, its perfect, ive bled it like 20 times
Old Aug 17, 2007 | 10:46 PM
Coblasts's Avatar
I think the dealers have a special machine for bleeding the lines because its such a problem with the Cobalts from what I have read in past posts.
Old Aug 18, 2007 | 01:11 PM
sunfirejoe's Avatar
can anyone confirm this or is he just talking about there special bleeding set-up that you can make
Old Aug 19, 2007 | 08:53 PM
sunfirejoe's Avatar
well my car is going into a shop now, cuz im out of time and patience, i have 2 weeks, to make my car run properly so its time to go to a shop
Old Aug 19, 2007 | 11:46 PM
RA122324's Avatar
Fill the reservoir and lave the cap off.
Loosen the bleed screw.
Slowly pump the pedal until all bubbles are gone.
Close the bleed screw.
Fill the reservoir. Replace cap.
Pump the clutch.
Report back.
Result?
Old Aug 20, 2007 | 12:51 AM
sunfirejoe's Avatar
wheres our bleed screws
Old Aug 20, 2007 | 01:10 AM
Kaisoboy's Avatar
Talking
When you were putting the upper trani line on there should have been a bleeder nipple where the line connects to the tranni. you can only get to it from the underside of the car. You may also need to put that plastic cap back on as you will probably get leaking. The machine the dealers use is called a vacuum bleeder. You can also go to a parts store and pick up a hand pump vac bleeder.
Old Aug 20, 2007 | 01:41 PM
supermantxz24's Avatar
is your flywheel modified from spec? if not thats your problem send your flywheel to spec and they will mod it for you. they said that the flywheel isnt the right setup for the clutch but they can mod it to work properly. i had the same issue now its all better im like 90% sure thats what it is
Old Aug 20, 2007 | 06:47 PM
sunfirejoe's Avatar
put it this way it worked for 27000 km before, i doubt thats my issue
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
